Lighting Circuits - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2013, 11:50 PM   #1
Rewards Points: 101
Lighting Circuits
In my home I have noticed that built in lights are always on their own circuit. For example, the guest bedrooms share a light circuit with the guest bathroom. The two guest bedrooms share a receptacle circuit and the master bedroom shares lights with the master bath, etc.
Is there a good reason why each room doesn't just have one circuit, or two smaller rooms share for everything?
michaelson is offline   Reply With Quote
Old 10-03-2013, 11:58 PM   #2
cost! each room could certainly be on its own circuit but the electrical demand for lighting is typically so low that adjacent rooms are often on the same circuit.
itsnotrequired is offline   Reply With Quote
Old 10-04-2013, 05:40 AM   #3
PoleCat's Avatar
Rewards Points: 1,654
Lighting circuits are often dedicated to only lighting and use 14 gauge wire and 15 amp breakers.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-04-2013, 05:59 AM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
With the high cost and requirements of AFCI's, i generally wire two bedrooms per circuit.... saves on cost, and bedrooms are such low powered required areas....
Wiring in a Jacuzzi tub...Says it needs 2 separate circuits? moparmaniac Electrical 12 01-17-2012 12:36 AM
Adding odd circuits in a bedroom and hood fan oh my! beatle Electrical 3 11-19-2009 07:45 AM
DIY Lighting Fixture stubits Electrical 11 10-13-2009 01:20 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
