Lighting Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2010, 08:22 AM   #1
lighting circuit
hi guys
is there a maximum amount of lights allowed on a lighting circuit? i have 14 pot lights and two outside lihts is that too many?
brit in canada is offline   Reply With Quote
Old 12-22-2010, 08:26 AM   #2
Electrician
Rewards Points: 910
Look at the lights and find the maxium size bulb that can go in the fixture(usually marked in wattage) add up all the wattages and then divide by 120. If your answer is below 12A you are good to go, if your over 12A you will need two circuits.
darren is offline   Reply With Quote
Old 12-22-2010, 08:30 AM   #3
Experienced
Jackofall1's Avatar
Rewards Points: 2,102
What is the capacity of the breaker feeding them, rule of thumb, 80% of breaker capacity. Local codes may restrict the total number of fixtures allowed.
Old 12-22-2010, 08:36 AM   #4
sorry really didnt explain myself, i am in ontario and under the 80% of the 15a breaker just didnt know if theres a max number allowed like there is with recs
Old 12-22-2010, 08:50 AM   #5
Experienced
Jackofall1's Avatar
My best guess would be 10/ circuit, just moved and my code book is in a stack of boxes in the basement.
Old 12-22-2010, 12:02 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 24,014
If you have only lighting then you can go with 80% rating of maximum allowed fixture wattage. If there is even one recepacle then you have a 12 outlet limit.
Can't get the master circuit breaker properly seated davefoc Electrical 1 03-22-2010 06:17 AM
lighting circuit design question amakarevic Electrical 15 10-31-2008 02:11 PM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 10:31 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
