Light Won't Work After Splice - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2010, 12:05 PM   #1
Light won't work after splice
Can anyone explain why after a section of wire was cut and re-spliced
, the light to which it was connected won't work. Thanks!
magnum is offline   Reply With Quote
Old 05-30-2010, 01:26 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 58
The splice was not done properly.
You should start a new thread and explain you situation better.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 05-30-2010, 03:04 PM   #3
Maybe when the wire was cut, it blew the breaker and it must be reset!
Old 05-30-2010, 10:40 PM   #4
Problem resolved. I re-checked the wires inside the junction box and although they seemed fine with a pull on the wire nut, a closer examination found the black wire was cut close to where the sheathing was removed. A few twists and the wire broke off. A new length of wire was exposed, re-connected and all is well!! Just goes to show how important a closer examination of a problem really is. Thanks to all who responded.
Ceiling fan light fixture doesn't work c4hfam Electrical 9 03-05-2011 02:01 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Wired a new light now dimmer doesn't work Smaster Electrical 5 05-01-2010 05:51 PM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 09:15 PM
ANOTHER ceiling fan light fixture doesn't work bandguy Electrical 8 06-13-2007 09:40 AM
