Light Switch Wiring (doesn't Look Normal) - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2017, 10:52 AM   #1
Rewards Points: 2
light switch wiring (doesn't look normal)
hi, new to the forum, was looking for some insights. i'm replacing a dimmer switch with a regular switch, and looking at how it was originally wired, its not exactly normal. It's not a 3way switch, the dimmer just controls the ceiling light in the room, but there are 3 sets of wires behind the dimmer.
-the 3 whites are all wound together,
-1 black wire from the dimmer is connected to 2 black wires,
-the 2nd black wire in the dimmer connects with the other black wire.
i've added a schematic...all i want to do is put in a regular switch.
would it be safe to assume wires 1 and 2 are middle of line and then 3 is the wiring to the light (an end of line).
would you pigtail 1 &2 and have that go to 1 terminal, and then the black3 would go to the other terminal?
my house was built back in the 80s and it looks like the original build wasnt exactly normal. it's all safe, but just weird. any comments would help.
light switch wiring (doesn't look normal)-screen-shot-2017-10-14-11.47.13-am.png
cmtodd is offline   Reply With Quote
Old 10-14-2017, 11:18 AM   #2
CodeMatters's Avatar
Rewards Points: 7,982
Re: light switch wiring (doesn't look normal)
That's normal. 1 & 2 are power in and power out. Doesn't matter
which one is which. 3 goes to the light.
Power is tapped off by the tail to power the light via the switch.
Add your new switch to the same wires and it'll work fine.
The wire nut on blk 3 isn't necessary and I'd eliminate it if the
wire is long enough.
edit: I now see the wires off the switch aren't tails, they're the
wires from the back of the dimmer.
CodeMatters is online now   Reply With Quote
Old 10-14-2017, 11:19 AM   #3
Rewards Points: 18
Run a pigtail from the two black wires that are connected together to one screw of the new switch (that is your incoming hot wire), and run the other black wire to the other screw on the new switch (that is your switch leg)
A pigtail is a 6 inch length of wire.
Sent from my SM-G530T using Tapatalk
jeffmattero76 is offline   Reply With Quote
Tags
3 wires , switch , wiring
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 09:37 PM
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 06:27 AM
Trying to replace electric mower switch with normal light switch orrgroup Electrical 6 06-12-2012 05:45 PM
Rerouting Bathroom Wiring roasted Electrical 36 05-13-2012 09:58 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
