Light Switch In Wet Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2010, 04:26 PM   #1
Light switch in wet wall?
I have an alcove tub/shower and a linen closet in the same bathroom. They share a partition wall that houses the tub/shower fixtures. Am I allowed to install a light switch for the closet light in that shared wall? All electric wiring and the switch is separated from the copper pipe and fixtures by a stud. I want to install it next to the PVC vent as shown in in the picture.
-rick
rick112 is offline   Reply With Quote
Old 05-04-2010, 04:36 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 946
Not a problem!
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 05-04-2010, 06:53 PM   #3
Just call me Andrew
Rewards Points: 1,032
As long as your pipe doesn't leak, that wall isn't wet
Andrew
secutanudu is offline   Reply With Quote
Old 05-04-2010, 09:59 PM   #4
Aw man, I was hoping for some cool unique situation. Oh well!
**edit - if you're concerned and want peace of mind, you could GFCI protect that circuit...**
brich is offline   Reply With Quote
Old 05-04-2010, 10:31 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Peace of mind? Seriously? What possible benefit would that bring other than lightening his wallet?
As long as the work is done properly there is absolutely no danger there. If the pipe bursts inside the wall the wiring in there is a minor concern in the scope of things.
Old 05-05-2010, 11:10 AM   #6
Thanks, I couldn't find anything about it in my NEC book and it just seemed like one of those things that might "not be allowed". The switch is on the same 20A circuit as the rest of the bathroom which is protected by a GFCI outlet near the lav. If the pipe were to burst, I would think that the ceiling lights in the room below would pose the most threat anyway.
-rick
Light switch failure help!! metalrex Electrical 22 02-04-2010 09:13 PM
Add new light and switch to a switch loop UncertainSparky Electrical 4 01-24-2010 08:58 AM
Grabbing power from a light switch box RedBear Electrical 3 01-13-2010 01:28 PM
What wall switch for bath fan/light/heater? janralix Electrical 6 07-20-2009 11:14 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
