Light Switch Unresponsive - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2009, 01:21 AM   #1
light switch unresponsive
one of my bedrooms has a lightswitch that doesnt do anything. it's the only lightswitch in that room and i've tried all the sockets. i dont have many electrical skills, is there an easy fix?
pollybest is offline   Reply With Quote
Old 09-23-2009, 04:50 AM   #2
the Musigician
DangerMouse's Avatar
is there a fixture on the ceiling?
DM
Old 09-23-2009, 04:58 AM   #3
dSilanskas's Avatar
Well first make sure there is power at the switch. Second the switch could go to a whip in the ceiling. The electrician might of prewired for a future ceiling fan/light. It really could be anything.
dSilanskas is offline   Reply With Quote
Old 09-23-2009, 05:01 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by pollybest View Post
.......and i've tried all the sockets.......
Polly, Welcome to the Forum
Duplex Receptacles are made so that they can be configured upon installation so that one of the Outlets is Switched and the other always has power.
Turn the switch OFF and try ALL the Outlets (top & bottom). Usually only one of the Outlets in a room without a mounted light fixture will be Switched.
Report the results
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-23-2009, 10:31 AM   #5
Is there a fireplace in the bedroom? Sometimes the builder will install a switch in the plans when there is an option for a blower, but the homeowner does not select that option.
log_doc_rob is offline   Reply With Quote
Old 09-23-2009, 12:46 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 30,998
Report the results
And that receptacle would have tab braken off between the two gold scews. If someone replaced the receptacles and didn't remove the tab on the receptacle, the switch would do nothing. The recepatcle would always be on now.
Old 09-23-2009, 01:37 PM   #7
Tool Geek
PaliBob's Avatar
Joed, Good point on the Tab. I annotated my pic to show the Tab location.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-24-2009, 09:31 AM   #8
ok, i tried plugging it into every outlet and one of them worked. thank you so much for the input.
Old 09-24-2009, 03:20 PM   #9
LeviDIY's Avatar
Rewards Points: 252
Joed raises an interesting question (without hijacking the thread as the issue has been resolved), but say all the receptacles have been replaced w/o tabs broken (as it appears with me... I have a "switch to nowhere" I've been trying to disgnose), would there be any clues on the wiring incoming to that receptacle to look for?
LeviDIY is offline   Reply With Quote
Old 09-24-2009, 03:34 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,460
One possibility is a red wire along with the black and white.
Another is a white wire coded with black tape and connected to the black wire of the incoming power.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 09-24-2009, 04:01 PM   #11
Tool Geek
PaliBob's Avatar
....... would there be any clues on the wiring incoming to that receptacle to look for?
Starting at the receptacle most likely to be switched i.e. an outlet close to where the bed might be placed:
  1. Remove the trim plate
  2. Check to see if there are two wires on the side marked 'TAB' in the pic
  3. If so, and the wires are different colors e.g. Black & Red then you've found it
  4. If the wires are the same color, check out the next most likely receptacle
This won't be as easy if the switch leg and AC are the same color but it will still help isolate the culprit outlet, because if you go around the room and only one receptacle has two wires on the side marked TAB in the pic then you’ve found it.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-24-2009, 04:07 PM   #12
LeviDIY's Avatar
Rewards Points: 252
I"m not even home and I think I have an idea which one it is... thanks!
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
Tracing light switch to an outlet allanet Electrical 13 04-03-2009 08:44 AM
A simple 2 light --1 switch question? [email protected] Electrical 7 11-05-2008 08:35 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
