Light Switch Controlling Multiple Rooms - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joed
Old 08-09-2019, 01:46 PM   #1
Rewards Points: 8
Light switch controlling multiple rooms
I recently moved into a home with electrical issues in 2 bedrooms. Both bedrooms have ceiling fans with lights. Bedroom #1 uses a remote in place of a switch to control the fan and light (all wires are capped). Bedroom #2 uses a normal switch.
The issue is that the power for bedroom #1 is controlled by the switch in bedroom #2. So the remote for #1 only works when the switch in #2 is on. #2 doesn't appear to have any issues otherwise. I need the power to each room to be separate. Any help would be appreciated!
Photos are coming in the next post...
Roah is offline   Reply With Quote
Old 08-09-2019, 01:48 PM   #2
Rewards Points: 8
Re: Light switch controlling multiple rooms
Photos of both are labeled #1 and #2 at this link
https: //imgur. com/a/ NESovuJ (please remove spaces. Apparently I'm unable to post direct links since this is my first post)
Old 08-09-2019, 01:49 PM   #3
retired framer
Rewards Points: 6,224
Put remote in for both and bi pass the switch???
Do not use flat bottom gables with scissor trusses.
Old 08-09-2019, 02:10 PM   #4
Rewards Points: 408
So, if I am understanding you correctly, the "switch in #1 is battery powered? As you said all the wires are capped. It looks like switch #2 might be switching the main live leg to your fan.
If you pigtail the blacks to the black wires all together on switch #2 this will allow fan #1 to work all the time. To get fan #1 to work via a switch I would leave one black wire coming from the pigtailed group and wire the red wire to the other side. You will then need to access the wires of the fan this switch controls and change its power wire to be the red wire. It looks like someone did a halfassed job of rewiring it at some point and mistakenly cut off live power by disconnecting the pigtail.
Sdiver2489 is offline   Reply With Quote
Old 08-09-2019, 02:36 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 30,566
Here are the images.
Old 08-09-2019, 02:39 PM   #6
Super Moderator
joed's Avatar
Does the switch in #2 control the light in #2 properly? To make it not control #1 connect the two blacks from the switch together but then I don't see how it can control the light. You need to open the light in #2 and show us those connections.
Old 08-09-2019, 02:50 PM   #7
Rewards Points: 408
Since the other box is jumpered from black to red I'm assuming the original wiring switched the red wire on the other box as well with the blacks all shorted together. You are correct that to know for sure we need to see the wires but I think its a safe bet that red goes to the fan.
Old 08-09-2019, 03:43 PM   #8
Super Moderator
joed's Avatar
Since the red is only shown connected in one box is likely that the two reds not connected.
I suspect there is a three wire cable to the light box.
Old 08-09-2019, 05:20 PM   #9
Rewards Points: 8
joed, thanks for posting the photos.
Yes, the switch in #2 controls the light in #2 properly.
Sdiver2489, yes the remote is bypassing the switch in #1.
Old 08-09-2019, 06:23 PM   #10
Master Electrician
Rewards Points: 5,224
The power is being sent through the switch instead of being connected to the constant hot at the switch location. It is mis-wired.
brric is online now   Reply With Quote
Old 08-09-2019, 07:05 PM   #11
Rewards Points: 8
Here is the diagram I put together. I left out the white wires and ground wires for simplicity. https: //imgur. com/a/RLHLK16
I've tried different ways and only came out with 2 different outcomes
Outcome 1) I connected F and G together and connected E (red wire) to the switch. Both Fan #1 and Fan #2 continuously had power and I could not turn off #2 so the switch was not working.
Outcome 2) Connecting E to either G or F or keeping E disconnected. The result here was that switch #2 controls both Fan #1 and Fan #2, which is the same result as in the previously posted pictures
Old 08-09-2019, 07:56 PM   #12
Super Moderator
joed's Avatar
Since switch has only two wires attached and controls both the light and the other room the problem has to be in the light.
We need to see the wiring in the light.
keep_hope_alive likes this.
Old 08-09-2019, 11:00 PM   #13
Rewards Points: 680
Is there an attic above? It's possible switch 2 was wired to fan 2, and then later someone installed fan 1 and just fed it from fan 2 and blanked over an existing switch 1 which only controlled outlet(s).
LawnGuyLandSparky is offline   Reply With Quote
Old 08-10-2019, 06:16 AM   #14
Rewards Points: 588
Power may be originating from fan #2. Switch power is then feeding fan #1 instead of the constant power at the fan box #2 feeding fan #1.
Or it can be like two offices where I work. Each office has only one light switch. both light switches control both offices (3 ways switching). Apparently it was one large office at one time and a wall was constructed to make two offices not separating the lighting.
afjes2015 is offline   Reply With Quote
