Light Switch In Bath Tub Alcove - Electrical - DIY Chatroom Home Improvement Forum
View Poll Results: Do GFI's for switches in a tub alcove (no shower) satisfy wet location issue?
If switches are offset from tub plane? 0 0%
Will a waterproof switch be okay? 0 0%
Would waterproofing the switch yourself work? 0 0%
Voters: 0. This poll is closed
Old 11-14-2017, 11:11 AM   #1
Rewards Points: 2
Exclamation
light switch in bath tub alcove
We had a room addition done with light switches shown on the plans in a tub alcove (off to side and not over tub, and no shower). It went through plan check, and the rough electrical inspection...but on final inspection, the inspector (the same one) now says no go.
The electrician had wired each switch individually and each with a GFI switch on the back side of the wall, which the inspector did not see or note in his final inspection (he might have seen it in the rough inspection and forgot?). The switches are over 12" from the end of the tub and off to the side of the tub..and over a wide granite tub surround for these offsets...
Much has been said in blogs on the NEC and "wet" locations/tub alcoves...but I saw no mention on if the individual GFIs satisfies the issue, or if it's offset enough to meet criteria.
Amazingly, if they weren't in the alcove, or if the tub and granite were a bit narrower..it appears the switches would be fine.. yet you could still reach them from the tub...???(sorry about the ramble)
Anyone know if the GFIs and offsets might satisfy the inspector???...thanks !!!
tails88 is offline   Reply With Quote
Old 11-14-2017, 01:20 PM   #2
Licensed electrician
Rewards Points: 3,840
Re: light switch in bath tub alcove
The NEC does not require gfi protection for the lighting , even if over the tub.
As long as the switches are not over the tub there is no distance requirement . Did the inspector say what the issue was? They need to provide the violation .
Need to add 2nd switch and 2nd light to room: Can this light be wired as 2nd light? HTFreak Electrical 1 12-06-2016 04:04 PM
Tiny voltage on bath light circuit when switch closed darsunt Electrical 10 01-14-2016 12:28 PM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Light Dimmer Switch Combination - Advice needed! me88me Electrical 18 08-09-2013 06:02 PM
Diagram for 3 way ceiling fan light switch Aurora65 Electrical 22 11-27-2012 09:11 AM
