Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2009, 09:33 AM   #1
light switch
i hav a light switch in garage that sometimes makes like a pop noise & then the tripp switch goes off? any ideas?
wayne18 is offline   Reply With Quote
Old 12-29-2009, 09:53 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 980
When you say tripp switch, do you mean breaker?
You have an intermintent short on that circuit.
Check the wires on the switch, and at the light fixture.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 12-29-2009, 10:31 AM   #3
Rewards Points: 2,800
If the switch innards are quite worn and don't click off fast, and if there is a considerable load on the circuit then a noisy spark will occur in the switch as it is turned off and a breaker equipped with an arc fault interrupter will trip.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 12-29-2009, 01:28 PM   #4
Light switches DO fail. How old do you think is that switch? Does the sound come from the switch, itself? I suggest replacement.
oberkc is offline   Reply With Quote
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
Tracing light switch to an outlet allanet Electrical 13 04-03-2009 08:44 AM
A simple 2 light --1 switch question? [email protected] Electrical 7 11-05-2008 08:35 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
