Light Spreading Tape? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2015, 05:50 PM   #1
Rewards Points: 6
Light spreading tape?
I'm going to buy those cheap angel eyes to my car: ebay.com/itm/4-x-Multi-Color-RGB-LED-Halo-Rings-Light-90mm-5050-Super-Bright-Angel-Eyes-/121437948117
But I absolutely HATE how the lights in the ring appears to be dotted. I would like a very clean ring of light instead of a dotted ring. So is there any tape that I could put on the led ring that is spreading the light so it appears not to be dotted?
I want it to look like this: g02.a.alicdn.com/kf/UT88cCJXbhgXXagOFbXD/202261260/UT88cCJXbhgXXagOFbXD.jpg
Sparkeflett is offline   Reply With Quote
Old 10-26-2015, 07:40 AM   #2
Rewards Points: 2,328
Try:
http://www.amazon.com/Amico-White-An.../dp/B006W2EKHE
bob22 is offline   Reply With Quote
Old 10-26-2015, 09:13 AM   #3
Rewards Points: 6
Originally Posted by bob22 View Post
Try:
Eh, I wonder why they don't want to show a picture of the LEDs in action... Probably beacuse it looks like ****.
Old 10-26-2015, 06:32 PM   #4
Rewards Points: 1,428
That angel eye thing is probably illegal. You should not be messing with your car's safety equipment.
poiihy is offline   Reply With Quote
Old 10-26-2015, 07:30 PM   #5
Rewards Points: 6
It's legal to install police red/blue LEDs everywhere on my car, I can even install a police light bar on my roof if I want to, as long as I don't use it when driving on public roads.
"Messing with my car's safety equipment", you have to be kidding? What's the worst thing that could happen, my lights go out, which is extremely unlikely since the LED rings will be connected directly to the car's battery and it will have a fuse...
If you would have any knowledge about electricity you would be aware that nothing bad can happen by installing some LED decorations on my car.
Old 10-26-2015, 08:40 PM   #6
Osh
Rewards Points: 40
Not cheap but what your looking for. Model specific.
http://oraclelights.com/automotive-l...CCFL-HALO-KITS
Osh is offline   Reply With Quote
Old 10-26-2015, 09:48 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
So buy those.
Old 10-27-2015, 04:17 PM   #8
Go to the automotive forum at CandlePowerForums and you will find why things like these are illegal.
The lights can cause distractions or glare.
Yes, ok, use what you want when you are out in the bushes, but don't use those toys when you are around other vehicles.
How will they be installed? If you modify your headlight housings you may mess up something like the beam which may cause wrong amounts of light going in the wrong directions which can make it difficult for you to see or cause glare to other drivers. Also, don't forget, whenever you replace your headlamp assemblies (by replace I mean remove and place back in again) you must re-aim them with a proper aiming machine.
Old 10-27-2015, 04:44 PM   #9
Osh
Rewards Points: 40
There's hardly a late model BMW made without these. Ambient lighting only, not for driving at night. No safety issues. http://www.hidefia.com/bmw-m5-dark/
Old 10-27-2015, 04:45 PM   #10
The ones in the BMWs are built-in to the assemblies from the OEM. They are not cheap ebay garbage that are glued into the headlights.
Old 10-27-2015, 09:01 PM   #11
I personally think it's tacky to try and simulate something like this from a luxury car. But then again, I'm not 19 any more either.
Old 10-28-2015, 01:05 PM   #12
It's not that the rings themselves are illegal. They just have to be implimented properly. The rings in the BMWs are engineered just like the rest of the headlight and they meet DOT requirements. Those rings from ebay are just SMD5050s on a circular PCB that you stick in your headlight.
There may be more of a problem with modifying your headlights. You might cause a problem when you hack your headlights. Those head light assemblies are very expensive and they are precise equipment. You should not be sticking toys in them. Headlights are not for looks. They are safety devices. They allow you to see at night. If your headlights are messed up, you may either not be able to see well, or you may see better (or think you see better) while blinding other drivers and increasing your chances of causing an accident.
BTW, if you do get in an accident, and the insurance company/ies find that you have hacked your headlights, you'd be at fault and you may not be covered.
Of course, it's your car, so do what you want. But why not just leave them alone?
Old 10-28-2015, 02:31 PM   #13
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,170
Ayuh,.... Step back a couple a hundred feet, 'n ya won't see dots, but circles,...
Hard Wiring vanity light fixture into outlet? qwiksilvertrav Electrical 16 02-24-2013 01:16 PM
ceiling light problem al gilliland Electrical 0 11-15-2011 04:05 PM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 08:36 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
