Light Inside Outdoor Shower - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-13-2013, 07:50 AM   #16
biggles's Avatar
seen this out in the Hamptons bunch of times or might consider low voltage lighting on a post or two
Old 08-13-2013, 07:58 AM   #17
Rewards Points: 85
So is that goose neck fixture low V? That's pretty nice!
JohnC20 is offline   Reply With Quote
Old 08-13-2013, 11:06 AM   #18
get a battery operated light and be rid of your problem!!
derrick smicer is offline   Reply With Quote
Old 08-13-2013, 11:18 AM   #19
Rewards Points: 4,284
Go solar and forget all the codes and yada yada yada. My wife bought some for the deck a few days ago for $0.50 each and they were working just fine in the rain the last I looked. At 50 cents each you could line the 3 walls at the top.
Old 08-13-2013, 11:18 AM   #20
Oso954's Avatar
Rewards Points: 1,280
No.
He was suggesting an alternative of LV on the posts.
If you like the fixture, you can get one quite similar at Lowe's.
Oso954 is online now   Reply With Quote
Old 08-13-2013, 01:59 PM   #21
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by JohnC20 View Post
From what I've read you should always run an insulated ground in wet locations. Is this not true?
Really? Interesting....
POOLS and SPAs ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 08-13-2013, 04:20 PM   #22
biggles's Avatar
any fixture can be made with a 24v bulb..might hit a flea market down there and catch one.its just a transformer within the garage 115v/24v wired thru a switch..mount the fixture and feed the wire into the 1900 ox with the TR mounted on it..break the 24v with the switch plate mounted TR just check the VA on the actual bulb going in...40VA maybe and inline fuse it with an auto glass fuse holder http://www.bestbuyheatingandaircondi...ode=TRA72D1683 if he goes 115v 20-30-40 bulb watts to light it up just like a porch light
Old 08-13-2013, 04:23 PM   #23
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
OK, but why bother with this?
Old 08-13-2013, 04:29 PM   #24
Rewards Points: 516
1900 box is not rated for WET locations ......
Old 08-13-2013, 04:35 PM   #25
Rewards Points: 516
anyway ....how about this ...
http://www.rabweb.com/downlights.php...e=products.php
Old 08-13-2013, 05:58 PM   #26
biggles's Avatar
your killing sparky ..the box is mounted on the other side of the wall the light is mounted on...in side the house or garage just the light is showing with no piping or boxes outside
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
confusion with track light stephenbishop Electrical 7 03-10-2012 01:37 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
