Light Inside Outdoor Shower - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2013, 05:47 PM   #1
Rewards Points: 85
Light inside outdoor shower
Hi all!
Hope you are enjoying the summer.
My question has to do with installing an outdoor light inside a shower. I have a small cottage near the beach in nj and its tough to take a shower in the dark outside. So I was wondering about throwing up a drawstring type fixture in the covered portion of the shower. I would run it off an existing internal power source with the breaker being GFCI. I would go with 14-3 cable with a coated ground. Any issues here concerning safety?
Thanks!
JohnC20 is offline   Reply With Quote
Old 08-12-2013, 06:17 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,682
A draw string inside the shower would never be code. You will need a water proof fixture with a switch outside the shower area.
Old 08-12-2013, 07:02 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
What is a "14-3 cable with a coated ground", and why would you think this is necessary?
Old 08-12-2013, 07:33 PM   #4
Licensed Pro
Sounds like SJ cord.
Old 08-12-2013, 07:44 PM   #5
Rewards Points: 85
It's a cable with an insulated ground wire instead of a bare copper wire.
Old 08-12-2013, 07:45 PM   #6
Rewards Points: 85
Thanks. My suspicion as well. Wasn't sure. How about the connection?
Old 08-12-2013, 07:47 PM   #7
Such as?
And what's the point?
Old 08-12-2013, 07:48 PM   #8
In the US the light must be wet location rated only if subject to shower spray.
Old 08-13-2013, 05:23 AM   #9
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
correct like in a shower area ...LOL or outside ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 08-13-2013, 06:01 AM   #10
Rewards Points: 85
Thanks. That is true.
Old 08-13-2013, 06:50 AM   #11
raylo32's Avatar
Rewards Points: 1,504
You might just get one of those battery powered stick on lights "as seen on TV". Should be plenty of light and battery life for infrequent shower use. It's not like you don't know where everything is anyway. ;-)
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 08-13-2013, 07:21 AM   #12
Rewards Points: 85
I had those. They work ok. Problem is they corrode because of the sea air. I end up tossing them out at the end of the summer.
Old 08-13-2013, 07:22 AM   #13
Rewards Points: 85
Such as?
From what I've read you should always run an insulated ground in wet locations. Is this not true?
Old 08-13-2013, 07:34 AM   #14
A "Handy Husband"
rjniles's Avatar
Rewards Points: 812
Not true. If you use cable, use UF type cable. 2 insulated conductors and a bare ground.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 08-13-2013, 07:35 AM   #15
Rewards Points: 85
Really? Interesting....
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
confusion with track light stephenbishop Electrical 7 03-10-2012 01:37 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
