Light Goes Dim And Re-lights - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2016, 05:24 PM   #1
Solutions (handyman)
Rewards Points: 490
Light goes dim and re-lights
A client of mine has an LED light that, when turned on, starts to brighten but when it is full strength, it goes dim and begins to brighten again. This action repeats over and over. What is the cause and how to correct?
Mark Harvey is offline   Reply With Quote
Old 12-30-2016, 08:24 PM   #2
Rewards Points: 3,125
Re: Light goes dim and re-lights
Is it getting constant voltage? Put a meter on it. Is there a dimmer or remote control or anything weird in the circuit? Can you remove the bulb and try it in a different location? Just replace the whole thing?
mathmonger is offline   Reply With Quote
Old 12-30-2016, 09:30 PM   #3
Msradell's Avatar
Rewards Points: 1,010
Definitely try a different fixture first, that will narrow down whether the problem is with the fixture or the bulb. If its a bulbs a solution is simple, just buy another one. If it see circuit it will take some more investigation to narrow down the problem. I'm guessing you are going to find that the problem is the bulb.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
