Light Fixture Whip Connected To Old Outlet Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2014, 06:34 AM   #1
Rewards Points: 2
Light fixture whip connected to old outlet box
I have a switched outlet high up on a wall that I'd like to use to power a new track light.
I'd prefer NOT to use a plugged-in power feed for the track. I'd prefer it to be hard wired. Note: I don't have access above the ceiling.
My thought was that I could use a small length of bx or armored cable to the track. My question is pulling power from the existing outlet box legit? Can you find a box cover with a knockout for conduit 90deg connector?
Thoughts on this approach?
Luchobucho is offline   Reply With Quote
Old 11-05-2014, 07:16 AM   #2
Rewards Points: 1,192
Yes,it's legit but there are new codes about controlled outlets in the 2014 N.E.C. so you might want to eliminate the outlet. If you use bx,the armour jacket is the ground so that eliminates using a plastic cover.
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
Luchobucho (11-05-2014)
Old 11-05-2014, 08:35 AM   #3
Rewards Points: 2
Good info. I forgot to mention I want to eliminate the outlet. The only thing to be controlled by the switch will be the light fixture.
Are the metal covers that have a standard hole for a conduit fitting?
Old 11-05-2014, 10:45 AM   #4
Rewards Points: 332
One like this:
should work.
sgip2000 is offline   Reply With Quote
Old 11-05-2014, 11:22 AM   #5
Rewards Points: 2
Last question:
Is this acceptable on an ice sting in-wall box?
Any issue with painting the exterior?
Thanks.
Old 11-05-2014, 06:19 PM   #6
Rewards Points: 2
So this is what I'm hoping to do, except up on a wall, not on the floor.
Adding a light fixture wiring question draconius Electrical 20 03-01-2013 10:56 PM
Hard Wiring vanity light fixture into outlet? qwiksilvertrav Electrical 16 02-24-2013 01:16 PM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 09:20 PM
Light controlled by switch, outlet always on, power at light...is this the way? pureevil Electrical 6 11-07-2010 05:32 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
