Light Fixture Socket Ring Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2016, 10:27 AM   #1
Newbie Bill
Rewards Points: 534
Light fixture socket ring issue
Hey Gang,
I have an issue that has arisen for the second time now and am wondering if it is just me that has this problem. And also looking for any solutions out there.
We have a problem where the ceramic socket ring that holds the glass shade up loosens up over time and the shade slowly starts to work its way off of the socket base. We have been lucky enough that we see it start to happen and get the shade off before it falls off.
I went to our Home Depot to locate replacements and they do not stock socket rings. I am going to stop in at one of the large light stores in town later today to see if they have a supply of replacements.
So does anyone else experience this problem?
Do you guys have any quick fixes for this or is obtaining replacement socket rings my only option?
Picture of socket ring attached in case I am calling it the wrong thing.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 02-22-2016, 11:29 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,018
Post an image of the entire fixture. I'm not sure those are meant to hold a shade.
Old 02-22-2016, 01:20 PM   #3
Rewards Points: 1,005
I've never experienced them backing off. I usually tighten them at installation pretty good. I always put the flange side on first, so I can gain access with needle nose on the nub side.
TimPa is offline   Reply With Quote
Old 02-22-2016, 01:34 PM   #4
Newbie Bill
Rewards Points: 534
I'll try to do that tomorrow.
Bill
Old 02-22-2016, 01:37 PM   #5
Rewards Points: 459
I would just add a rubber O-ring under it.
Nick DIY is offline   Reply With Quote
Old 02-22-2016, 04:43 PM   #6
Newbie Bill
Rewards Points: 534
It gets darn hot in there so I thought the rubber O-ring would melt. Am I wrong about that? Are there are o-rings available that are designed for high temperature situations?
Bill
Old 02-22-2016, 06:36 PM   #7
Rewards Points: 3,136
Most sites list Buna n "O" rings rated for 250F and Viton "O" rings 350F and 400F on some sites.
Old 02-22-2016, 08:49 PM   #8
Licensed electrician
Rewards Points: 3,688
I have never had them back off.
UnPhased347 (02-22-2016)
Old 02-22-2016, 08:58 PM   #9
Rewards Points: 72
Does that ring screw onto a ceramic insulator around the socket, or does it attach straight to the negative metal shell?
UnPhased347 is offline   Reply With Quote
Old 02-22-2016, 11:14 PM   #10
Newbie Bill
Rewards Points: 534
It screws on a ceramic insulator.
I went to a big light store in town this afternoon and they had one laying around that they gave me. It is very obvious that the old ring is about a 1/16th of an inch larger in diameter than the new one. So it seems the original ring either came too large or expanded over time. So I think I should try to locate a few more replacements as we have 3 of these fixtures.
I will keep that o-ring idea in mind as well.
Thanks guys.
Bill
Old 02-23-2016, 10:18 AM   #11
Newbie Bill
Rewards Points: 534
Hey Joed, here is a photo. Sorry, didn't take one of the entire fixture, but I hope you get the idea.
Bill
Old 02-23-2016, 10:23 AM   #12
Rewards Points: 1,832
Originally Posted by drtbk4ever View Post
A light bulb.
Probably 60 watts as that is what I use. Until I went to LED. Because I wanted lower electric bills. Make sure the wattage of the bulb. Is the right size for the fixture. 100 watts, it can get to hot.
As for the ring. Just twist it back on with the shade.
Jump-start is offline   Reply With Quote
Old 02-23-2016, 10:48 AM   #13
Rewards Points: 72
On boats we call incandescent lights "churn bogglers". Never knew why.
Old 02-24-2016, 10:38 AM   #14
Newbie Bill
Rewards Points: 534
After googling and googling, I actually found this...
http://www.rona.ca/en/socket-ring-11805656
Picked one up yesterday and it actually works. Whew.... It is plastic so I will keep an eye on it.
Thanks for all your input gang.
Bill
Old 02-24-2016, 12:31 PM   #15
Rewards Points: 118
If you don't need to take the shade off to change the bulb, have you considered putting a small dab of glue on it where the ring meets the threads? It should keep it in place and if you just use a bit you should be able to break the bond if you really need to get it off
zolakk is offline   Reply With Quote
Sealing an exterior light fixture box neb2489 Electrical 4 04-24-2015 10:40 AM
Replacing circular fluorescent light fixture - grounding issue DynamoDan Electrical 13 05-10-2013 04:57 PM
Adding additional light fixture to switched circuit woodardhsd Electrical 5 07-07-2011 10:06 PM
HELP! Wiring 2 switches with new light fixture michugana Electrical 7 04-10-2011 07:49 PM
Light fixture issue baustin Electrical 4 07-17-2007 05:01 AM
