Light Fixture Separated From Ceiling Fan - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-03-2015, 12:21 PM   #16
Rewards Points: 104
We got the light fixture down and I think we discovered our problem. What the hell kind of crap is this nut??
Anianna is offline   Reply With Quote
Old 07-03-2015, 12:43 PM   #17
Rewards Points: 127
You got it right. Cheap a## nut made in China spec by an American company to produce the cheapest thing possible that will kind of do the job crap nut
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
gregzoll (07-03-2015)
Old 07-03-2015, 01:25 PM   #18
Rewards Points: 104
What holds the motor housing up? Should I be checking for another PoS nut before the whole thing comes down?
Old 07-03-2015, 08:45 PM   #19
Rewards Points: 2,840
It depends how it's hooked up to the electrical box. Newer ones have a ball and socket that attaches to the electrical box as in the example shown below. Usually there will be some kind of bracket that attaches to the electrical box which secures the motor housing.
You would have to disassemble it to see how it's secured. It may be a good idea that way you can check the integrity of the electrical box.
Imo, it may be easier to replace it at that point. It's a very nice looking ceiling fan, but I don't know if you will find any parts for it.
jmon is online now   Reply With Quote
Old 07-03-2015, 09:59 PM   #20
Rewards Points: 104
So, now we have a new problem. The fan chain doesn't work and I can't have the light on and the fan off at the same time.
Somewhere, the wiring went wonky...
Old 07-03-2015, 10:40 PM   #21
Rewards Points: 6,652
I had that issue with one of mine. I put in a remote control that turns the light on & off, same as the fan.
They are in the lighting area where the fans are a Lowe's, etc. If you go to a Ace Hardware, they may have a limited amount or none, along with price could be more than what you would pay at the others.
You will have to take the fan back down again, which makes it easier to install on the fan side.
Old 07-03-2015, 11:21 PM   #22
Rewards Points: 888
Judging by the very cheap nut, it is likely that this fan was not intended to have a light kit. The nut would probably have held the fan finish piece but not with the extra weight of a light kit.
It was probably added by previous owner and may have held for awhile, but the yanking on the chain(s) for fan and/or light pulled off the nut and the unit came down.
Gregzoll is deadon. I'd get a new fan. see also:
http://www.diychatroom.com/f18/repla...ng-fan-285698/
diyorpay is offline   Reply With Quote
Old 07-04-2015, 12:34 AM   #23
Rewards Points: 199
Geez. That fan looks like it came from 1982. That's the year I put up my first wood and brass fan. Styles have changed and you can get a decent fan for $50 these days. Look for the ball and socket arrangement pictured above. IMO it's the easiest hanging system as you can have the fan hanging while you connect wires.
Arlo is offline   Reply With Quote
Old 07-04-2015, 05:50 AM   #24
A "Handy Husband"
rjniles's Avatar
Rewards Points: 430
$50 for a decent fan???? Buy a Hunter.
My electrical answers are based on 2014 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
gregzoll (07-04-2015)
Old 07-04-2015, 10:20 AM   #25
Master Electrician
Rewards Points: 5,270
The whole problem with this thread is that the black bottom cap of the fan to which the the light kit mounts is missing! The light kit mounts to the cap and the cap mounts to the fan.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
jmon (07-04-2015)
Old 07-04-2015, 11:49 AM   #26
Rewards Points: 888
brric is right. Cap is missing. But even if it were there and the light kit were mounted to it, if the only thing holding the fan part to the downrod was that ugly screw, same thing would happen.
Old 07-04-2015, 05:23 PM   #27
Rewards Points: 199
Yes I agree. But OP seems to be so poor she is fixing a dusty 30 year old fan. I wanted to offer an economical alternative. Walmart has some real cheapies for $39.99. Anything is better than fiddling with wires when you don't know what you are doing.
Old 07-04-2015, 06:43 PM   #28
A "Handy Husband"
rjniles's Avatar
Rewards Points: 430
Don't try to sleep in the same room while it's running.
gregzoll (07-05-2015)
Old 07-05-2015, 06:45 PM   #29
It should have came down on day one, and placed on the curb. You can get a Ceiling Light fixture for around $5-10 any were.
Tags
assembly , ceiling fan , light fixture
mounting fixture to light box without ceiling Gary Phillips Electrical 5 07-17-2013 12:14 AM
Ceiling Light Fixture Marama Electrical 5 05-19-2013 09:06 AM
New light fixture on false ceiling Metallo Electrical 12 04-17-2011 08:29 AM
Light fixture in ceiling fan won't work. Tested DIYself Electrical 7 11-28-2010 11:52 AM
Problems Installing a Light Fixture onto a Ceiling Fan adk97 Electrical 4 08-16-2010 05:30 AM
