Light Fixture Install Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2015, 11:39 AM   #1
simeltzer's Avatar
Rewards Points: 54
Got a quick install question. Although I have installed a bunch of fixtures in amy house in the past I had a question about this one (id like to make sure I do it the best way). The pictures show what I would assume is a 12-3 configuration. The old fixture was connected to the red/hot which I thought was for 3 way operation (this is not a 3 way fixture). Obviously my white/neutrals go together. Does it matter which hot (red or black) I use? Also should I connect the ground to the green mount screw or bundle it with the other bare wires? I assume the green screw is best because the fixture wire is stranded and the rest obviously isn't.
Light Fixture Install Question-img_1922.jpg   Light Fixture Install Question-img_1924.jpg
simeltzer is offline   Reply With Quote
Old 03-08-2015, 12:03 PM   #2
Licensed electrician
Rewards Points: 3,740
You may have a constant hot and a switched hot or two switched hot on the red and black.
All the ground should be spliced together and to the bracket.
Old 03-08-2015, 12:32 PM   #3
Master Electrician
Rewards Points: 5,264
Connect the new fixture to the same wires the old one was connected to.
brric is offline   Reply With Quote
Old 03-08-2015, 12:53 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,936
If the old fixture was connected to the red and white and you want you new fixture to work the same, then connect it to the red and white as well.
The box could have been set up for a fan which requires two hot, one for fan and one for light.
Old 03-08-2015, 02:28 PM   #5
simeltzer's Avatar
Rewards Points: 54
That sounds about right. Thanks again for the advice guys.
Adding Light Fixture from Light Switch BigBubba Electrical 2 01-19-2015 05:11 PM
Light Wiring Question mataguri Electrical 4 11-09-2011 02:15 AM
Basic wiring question when changing light fixture diydan Electrical 3 10-18-2011 06:29 AM
My light fixture / socket question. Getson Electrical 13 02-25-2009 03:41 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
