Light Fixture Help!!! - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2010, 05:16 PM   #1
light fixture help!!!
Hi Gurus,
Quick question I have just had my house resided and they installed these mounting blocks on my house they are just square and I have the tree wires one ground all coming out. Now the fixture instructions say connect it using the mounting block with these metal things (sorry dont know the technical name it has a green screw in it) I dont have that type of box. My box is found below its letterally just a plastic square. Do I juts connect the wires using wire nuts and mount the fixture to the box with screws? Sorry in advance im not technical just an accountant trying to install some light fixtures. heres a link to the boxes i have installed. BTW I already zapped myself lol... so now the breakers off!!!
http://www.homedepot.com/webapp/wcs/...07&marketID=39
workingonit is offline   Reply With Quote
Old 07-31-2010, 05:21 PM   #2
sorry if I was bit unclear. As to the ground wire as well I am wondering do I just connect that to the one coming out of the wall? I have it all connected and the light works I just want to make sure before I button it up im not missing anything.
Old 07-31-2010, 07:06 PM   #3
It may help to describe the colors of the wire from the house. I think I am pretty confident, however, that if you connect the green wire from your fixture to the bare copper wire from the house with with wire nuts you should be good. Black from the house is hot. White is neutral. There are probably a black and and white wire from your fixture. Black-to-black. White-to-white.
oberkc is offline   Reply With Quote
Old 07-31-2010, 07:20 PM   #4
dSilanskas's Avatar
If you don't have a metal box then you don't have to worry about grounding the box. Just go color for color and hang the light. Usually you will have a green ground scew on the fixture bar if you have one but if you don't then you don't need to worry about it.
dSilanskas is offline   Reply With Quote
Old 07-31-2010, 07:47 PM   #5
Thanks 4 your help guys! I'm allhooked up and they're working!!!! Look sharp lil zap wasn't fun but I'm alive!!! Haha. There was no metal box just white black and copper (ground) matched cables mounted fixture through the box to sheathing .........as always thanks a millie!
Old 08-01-2010, 07:24 AM   #6
Licensed electrician
Rewards Points: 3,662
Hate to be the one to tell you but an electrical junction box should have been installed thru that siding block. Electrical splices are required to be in junction boxes. What you have installed is not an electrical junction box.
Bathroom Light Fixture with no junction box? shadowman Electrical 2 07-13-2010 06:54 AM
Light Fixture wiring help jdpitt05 Electrical 7 07-12-2010 01:09 PM
outdoor light fixture kills everything on circuit kramwens Electrical 10 10-10-2009 03:50 PM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 09:26 PM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 12:49 PM
