Light/Fan And Receptical - Electrical - DIY Chatroom Home Improvement Forum
Old 07-30-2010, 03:19 PM   #1
Light/Fan and receptical
I ran the feed to the fan/ light combo first with 12-2 wire
then 12-3 to the wall switch and 12- 2 out from the switch to 3
recepticals.
I need some help on what wire goes were
kevin l is offline   Reply With Quote
Old 07-30-2010, 04:50 PM   #2
Licensed electrician
Rewards Points: 3,662
How many switches do you plan on using with the fan and light? Will the receptacles be hot all the time or switch controlled?
Old 07-30-2010, 05:58 PM   #3
I do want the receptacles to be hot all the time
and keep the fan hot. and the light to work with a switch on the wall
using only one wall switch
AboveGround Pool Filter Receptical dcd22 Electrical 5 03-02-2010 01:18 PM
adding a receptical CyndiLou Electrical 7 02-02-2010 09:05 AM
Upsidedown receptical? Giles Electrical 26 01-29-2010 11:07 AM
15a receptical on 20 amp circuit? fabian Electrical 9 03-05-2009 11:32 AM
Can I use a 20amp outlet receptical on a 15amp circuit? abefroman Electrical 17 01-18-2009 09:57 PM
