Light Fan Control Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2010, 10:40 AM   #1
jburd964's Avatar
Rewards Points: 172
Light fan control switch
I have a pair of ceiling fans that were installed in series with 12/2 wire single run. Lights and fans only works off pull cards. I had a fan in a pervious house that had a smart controller that ran both fan and light from 12/2 that controlled both speed and dimmer thru this single wire with low voltage signals. Does anyone know on a setup that would do that after being installed in off the shelf fan light combo?
jburd964 is offline   Reply With Quote
Old 06-25-2010, 11:38 AM   #2
Rewards Points: 308
Sure. All you need is a remote and a receiver. Lowes or Home Depot sells them. $30.00.
Old 06-27-2010, 12:38 PM   #3
jburd964's Avatar
Rewards Points: 172
I neglected to mention that there are two fans on same switch..
Old 06-28-2010, 06:56 AM   #4
The remote and reciever is the only options I have seen without rewiring. With two fans, perhaps an extra reciever would work?
oberkc is offline   Reply With Quote
Old 06-28-2010, 07:03 AM   #5
jburd964's Avatar
Rewards Points: 172
I was thinking the same thing.
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Removing a light source from a 3 way switch ecsedlak Electrical 4 11-29-2009 10:46 AM
Additional Wall Switch to control light tiame Electrical 6 07-03-2009 11:54 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
