Light Bulbs - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 02:26 PM   #1
Light bulbs
Can anyone explain the difference between these two types of bulbs? One person told me one is incandescent and the other is halogen, but the person at Lithonia Lighting said they were both incandescents.
30 R20
35 PAR20
hgtv is offline   Reply With Quote
Old 08-04-2010, 02:37 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Halogen IS incandescent.
The "R" is a standard reflector lamp.
THE "PAR" is a parabolic reflector lamp like an outdoor flood.
Smaller PAR (20 & 30) lamps are almost always Capsylite style halogen, while outdoor lamps (PAR38) are not always.
Old 08-04-2010, 02:56 PM   #3
Rewards Points: 558
The first one is a 30 Watt long life R20 flood light which gives you approximately +/- 20,000 hours and has a medium base.
The second one is a 35 watt par20 halogen wide flood light which gives you approximately 2,500 hours and has a medium screw base also.
Both can be used indoors and will fit in a standard household base.
A Incandescent bulb is widely used in household and commercial lighting, the very day run of the mill bulbs for portable lighting such as table lamps, car headlights, and flashlights, and also for decorative and advertising lighting. The above mentioned lights are used for specific applications.
epson is offline   Reply With Quote
Old 08-04-2010, 03:34 PM   #4
There is no way to tell if a lamp is "long life" or not just by it's designation.
A 30R20 is a 30 watt, Reflector lamp, that is 20 eights of an inch (1/8") in diameter.
Several factors determine long life. Many times it is manufacturing the lamp rated for 130v but designed to work on a 120v system. The light output is less than a standard 120v lamp but the life is increased.
Also, I think you have a typo there. It is 2000 hours, not 20,000.
Old 08-04-2010, 03:40 PM   #5
Thanks for the clarification Speedy. So, if you were to order bulbs for the dining/living room area, which ones would you get? I plan to order the Lithonia 301 trim with the L3R housing.
Old 08-04-2010, 03:53 PM   #6
I like the light better from PAR lamps. It is generally a crisper, whiter light.
Old 08-04-2010, 03:55 PM   #7
PAR = Parabolic Aluminized Reflector
You want the food to look natural so color temp. is important.
halogen = "incandescent except that a small amount of a halogen gas has been added to the inside of the glass envelope"
"High-quality halogen incandescent lamps have higher efficacy, which will allow a 60 W bulb to provide nearly as much light as a non-halogen 100 W. "
The color temp is also different with halogen.
http://en.wikipedia.org/wiki/Halogen_lamp
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Light bulbs blowing,,, Woodcutter Electrical 12 09-15-2009 06:24 PM
Light bulbs burning out Michblaze02 Electrical 12 03-19-2009 12:18 PM
Ceiling Fan Light Bulbs? kennykenny Electrical 7 07-29-2008 07:16 AM
clear light bulbs versus white ugabulldog Electrical 5 04-19-2008 10:42 AM
