Lifespan Of LED Bulbs - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree9Likes
Old 02-13-2019, 11:09 AM   #31
Rewards Points: 132
Re: Lifespan of LED Bulbs
I purchased a Commercial Electric, LED ceiling light fixture. It's about 1.5 inches deep and 12 inches in diameter. It replaces an old incandescent with a glass globe. The first one I put in was rated "bright daylight", which was way to bright. The second one I purchased to replace it has a switch on it so you can change the "temperature" of the lighting to one of 3 positions: 3,000, 4,000, 5,000. The fixture is in a hallway, and I find that 3,000 is just right, the other positions being way to bright.
Tom153 is offline   Reply With Quote
Old 02-13-2019, 11:27 AM   #32
Rewards Points: 132
I agree with the post that the LED fixtures seem work much better than the retrofitted LED bulbs that screw into a base to replace an old "Edison" style light bulb. All the pre-mature failures of LED bulbs have occurred in LED's that imitate the "edison bulb", and in overhead canisters. Also, I had a couple of CREE LED bulbs, screwed into a lamp fixture, but the glass was way too thin and it cracked around the base. The glass "globe" could be lifted off of the LED; not good.
Has anyone had any good results with replacing bulbs in overhead canisters? Eco-Smart LED bulbs seem to last longer than others. I was wondering if anyone has installed the more expensive LED trim canister replacements, where the LED is in a thin fixture that fits into the bottom of the canister and replaces the trim, and has a wire adapter with a threaded connector to screw into the old screw base. (example:"4 in. White Recessed LED Trim with 2700K, 90 CRI (2-Pack)").
Old 02-13-2019, 12:14 PM   #33
Oso954's Avatar
Rewards Points: 1,790
I was wondering if anyone has installed the more expensive LED trim canister replacements, where the LED is in a thin fixture that fits into the bottom of the canister.....
You should have a better success rate with them because the electronics are near the bottom of the can. They are not up near the top of the can where the heat gathers, like they are with the LED replacement bulbs.
Oso954 is offline   Reply With Quote
Old 02-14-2019, 01:49 AM   #34
Rewards Points: 474
With the new filament type bulbs the operating temperature range tops at 120C (248 F) according to the spec sheet for the electronics:
https://voron.ua/files/pdf/micoshema/CYT1000B.pdf
Here's a take-apart:
I think the problem is just new teething pains in the product.
tmittelstaedt is offline   Reply With Quote
Old 02-14-2019, 05:02 AM   #35
A "Handy Husband"
rjniles's Avatar
Rewards Points: 606
120° C is the upper range for the electronics, the lamps do not run any where nearly that hot. They are only warm to the touch.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 02-15-2019, 01:04 AM   #36
Rewards Points: 474
Which is why we should hopefully get more lifespan out of the newer bulbs. Sounds like the older electronics for these bulbs did not have as high a temp range.
Light Bulbs LED or not? fireguy General DIY Discussions 32 03-27-2016 01:26 PM
Base of these LED bulbs too hot? darsunt Electrical 3 11-11-2015 01:02 PM
Replacing T12 bulbs with T8 bulbs Msradell Electrical 3 01-22-2014 08:29 AM
Light Bulbs blowing all the time. lrcc Electrical 16 02-16-2013 07:40 AM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 05:25 PM
