Leviton Decora Lighted Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-15-2010, 02:22 PM   #1
Leviton Decora Lighted switch
I have a 4 lamp T8 fluorescent ceiling fixture in the kitchen. Can I use a lighted Leviton Decora switch #5611 to control it? I now hear that it may not be for fluorescent fixtures. Is this true?
Regards,
Mike
Mike2401 is offline   Reply With Quote
Old 12-15-2010, 06:35 PM   #2
Yes u can as long as it is not a dimmer switch
heartlessmcfly is offline   Reply With Quote
Old 12-15-2010, 09:02 PM   #3
" Euro " electrician
frenchelectrican's Avatar
It can be used but the only gotcha is electronic ballast it may flicker when the switch is off postion { lighted handle when load is off } but magatic ballast naw not a issue it will handle just fine.
So try it but if flicker then you will know the answer.
Otherwise take a quick peek at the ballast label it will useally tell which type of ballast it have so you will know what it have there.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Mike2401 (12-16-2010)
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
Switch now controls large area... froddan Electrical 5 12-06-2009 10:04 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
