Leviton To Cooper Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 10:33 AM   #1
Exclamation
Leviton to Cooper Wiring
I am replacing some old switches in my bathroom and came across this issue.
Switches with the wire stab in the back.
There are three switches as pictured, and I bought three single pole switches to replace. Do I need to return these and get three way switches?
It looks like the each switch has a jumper to the next one.
dreamslikefire is offline   Reply With Quote
Old 03-14-2010, 10:44 AM   #2
I think all three circuits share a neutural.
bkeech is offline   Reply With Quote
Old 03-14-2010, 10:46 AM   #3
How would I wire that up using a switch like this?
Old 03-14-2010, 10:49 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 942
Take a small screw driver, push in the tabs and remove the wire. Connect the wire to the new switch using the screws.
Where you have a wire using the backstab and the screw, wirenut the wires together and add a piece to reach the screw.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 03-14-2010, 10:50 AM   #5
Master Electrician
Rewards Points: 5,078
Those are not 3-way switches they are single pole. The hot wire is going to the first switch on the left where it is wrapped and continues on to the second switch and then on to the third via the backstab.
You should:
Turn the power off
Use the wire in the box mentioned above and pigtail three wires to it
Take each top wire from each switch and put it on a new switch
Take one each of the pigtailed wires and put one on each remaining screw of each switch.
Disregard comments about shared neutrals.
Looked at photo wrong
Left hand switch with lower backstabbed wire is the hot wire that should have three ne wires pigtailed to it.
brric is online now   Reply With Quote
Old 03-14-2010, 10:55 AM   #6
I just threw this together, this is my take on what you guys are telling me. and I thank you VERY much for your help. I build websites, not houses
Old 03-14-2010, 10:56 AM   #7
Master Electrician
Yes that is correct.
Old 03-14-2010, 10:57 AM   #8
jbfan's Avatar
Rewards Points: 942
Yep, a pigtaill for all the hot wires, then the switched wires by themselves.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cooper or Leviton GFCI? DIYGST Electrical 19 06-22-2009 09:30 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Leviton 8599 GFCI wiring issues Ultrarunner2017 Electrical 4 02-06-2009 08:53 AM
