Length Of Wiring From Panel To Generator Inlet Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2019, 04:17 PM   #1
Rewards Points: 129
Length of wiring from panel to generator inlet box?
Iím looking to install a generator inlet box on the outside of the house and run it to the breaker box to an interlock switch setup.. Would a run of about 40ft be acceptable from the inlet to the breaker box?
Maine1 is offline   Reply With Quote
Old 10-18-2019, 05:00 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 64
Re: Length of wiring from panel to generator inlet box?
40 feet is no issue at all.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 10-18-2019, 05:07 PM   #3
Rewards Points: 1,916
Not an issue as long as the wire size is correct.
Old 10-18-2019, 06:26 PM   #4
Rewards Points: 129
Is there a chart or guide for wire size for a specific length and load?
Old 10-18-2019, 06:54 PM   #5
Deleted Member
Shadow99's Avatar
Rewards Points: 136
Of course there is
I'll assume your in the US, so NEC applies. If you post the watts of your gen, someone will help you out.
As RjNiles said, 40' is not an issue.
Shadow99 is offline   Reply With Quote
The Following User Says Thank You to Shadow99 For This Useful Post:
Maine1 (10-18-2019)
Old 10-18-2019, 06:59 PM   #6
Rewards Points: 129
Thanks! Turns out I have another issue so I started a new post..
Old 10-18-2019, 07:03 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 64
Size the wire based on the capacity of the gen set.
Sent from my RCT6213W22 using Tapatalk
Old 10-18-2019, 08:53 PM   #8
Maintenance / Locksmith
Rewards Points: 436
How big is the generator?
georgemcq is offline   Reply With Quote
Old 10-20-2019, 04:26 PM   #9
Rewards Points: 12
Question
I have a similar question. I am installing a 30A transfer switch for a 8000W generator. Distance from the switch to power inlet box is approximately 30ft.
How thick should the wire be?
I am planning to use 10/3 armored cable - is it ok?
bambuk6 is offline   Reply With Quote
Old 10-20-2019, 07:36 PM   #10
Super Moderator
joed's Avatar
Rewards Points: 126
30 feet is not a length that needs to be oversized. #10 is fine.
