LED Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2010, 09:20 AM   #1
LED Transformer
Will magnetic cabinet closures interfere with an LED transformer for under-cabinet lighting?
kevinsworth is offline   Reply With Quote
Old 04-24-2010, 09:35 AM   #2
gmhammes's Avatar
Based on my experience, they should not interfere.
gmhammes is offline   Reply With Quote
The Following User Says Thank You to gmhammes For This Useful Post:
kevinsworth (04-25-2010)
Old 04-24-2010, 09:40 AM   #3
No. Permanent magnets put out a DC field, t'formers put out an AC field.
But, in a century [?] or so, the t'formers field will demagnetize the closure.
The Following User Says Thank You to Yoyizit For This Useful Post:
Old 04-25-2010, 09:38 AM   #4
Thanks so much for the replies!!
I'm adding Corbels under my wall cabinets, as well as the LED lighting. The receptacle I installed for the LEDs is directly over one of the Corbels, so it has to be "removable" in order to access the receptacle. Magnetic Cabinet "catches" will do the trick nicely, but I had concerns about the magnets being so close to the Transformer. It's okay if they demagnetize in a century, the life expectancy of the LEDs is only 50k hours!!!
Thanks again.
Unable to find out how to wire a dimmable light transformer Maleko Electrical 9 02-07-2010 01:07 AM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 11:10 AM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 08:21 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-21-2007 11:08 PM
