LED Lights Flash When Off! - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By gloriousglenn
  • 1 Post By gloriousglenn
Old 03-22-2018, 04:35 PM   #1
gloriousglenn's Avatar
Rewards Points: 49
LED Lights Flash when Off!
Hi,
I had some hologen puck lights installed under my kitchen counters. I wanted to replace them for one reason or another and went and got some "advice" as to what I needed. I have attached photos of the lights for reference.
Anyway, I unplugged the lights, leaving the remaining wiring (they are hardwired to a dimmer switch) and connected the new lights. All seemed to work well until I go to switch them off and they just flicker/flash rather than going off.
What am I doing wrong?
Cheers
Glenn
LED Lights Flash when Off!-20180318_215215_hdr_1521750908121.jpg   LED Lights Flash when Off!-20180318_215234_hdr_1521750937376.jpg
gloriousglenn is offline   Reply With Quote
Old 03-22-2018, 04:53 PM   #2
Guapo
Rewards Points: 11,950
Re: LED Lights Flash when Off!
It sounds like the dimmer isn't working right. Disconnect the dimmer. See what happens then.
Guap0_ is offline   Reply With Quote
Old 03-22-2018, 05:56 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 680
Does the switch have a pilot lamp built in? Another cause for flashing of CFL and LED's.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 03-22-2018, 06:19 PM   #4
Rewards Points: 49
This is the switch (attached). I'm going get a "normal" non-dimming switch and try that. Thanks guys.
chandler48 and Guap0_ like this.
Old 03-22-2018, 07:28 PM   #5
CodeMatters's Avatar
Rewards Points: 7,346
Changing to regular switch is worth trying. I'd also try pulling the switch
and receptacle out of the box and separating the wires as far as possible
and trying it that way. Takes very little induced voltage to make an LED
flicker.
CodeMatters is online now   Reply With Quote
Old 03-22-2018, 10:38 PM   #6
Newbie Bill
Rewards Points: 534
The dimmer is likely not rated for Led lights.
Sent from my iPad using Tapatalk
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 03-22-2018, 11:14 PM   #7
Disrespectful to dirt
Fishbulb28's Avatar
Rewards Points: 2,050
Are you actually switching the lights off or merely pulling down the dimmer slider when this occurs?
Fishbulb28 is online now   Reply With Quote
Old 03-23-2018, 10:25 AM   #8
Rewards Points: 49
So the wife says that the dimmer isn't important, so I'm going to get a regular switch and see if that works.
And yes I was switching it off rather than just dimming it down
Old 03-23-2018, 11:40 AM   #9
No reason an incompatible dimmer would be an issue when in the
off position.
Old 03-23-2018, 01:05 PM   #10
Newbie Bill
Rewards Points: 534
off position.
What you say makes complete logical sense. However, I had a similar issue as the OP where the lights would flash, even when the switch was turned off. I changed it out for a dimmer that was made for LEDs and no more flashing lights.
Here is the dimmer set up I have.
Bill
Old 03-24-2018, 08:43 AM   #11
Rewards Points: 49
Just to let you know that I removed the dimmer switch and replaced it with a "normal" switch and it all now works perfectly.
Thanks to all for your help and input.
Cheers
Glenn
Old 03-24-2018, 09:58 AM   #12
Guapo
That's what I said in post #2.
Old 03-24-2018, 10:19 AM   #13
Rewards Points: 49
Which is why I wrote saying thanks for peoples input.
MTN REMODEL LLC likes this.
2004 Ford Focus head lights. Nealtw Automotive Repairs 16 02-06-2018 02:33 PM
Hair dryer causing dimming of lights in multiple rooms xuandu Electrical 11 02-05-2018 02:12 AM
Dimming lights when neighbor's AC kicks on Elh Electrical 7 07-16-2013 10:44 PM
Replacing existing recessed soffit lights miamicuse Electrical 35 06-22-2013 08:52 AM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
