LB Or Elbow - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2009, 05:37 PM   #1
LB or elbow
I was wondering what everbody use after you enter the building under the panel to transition up to the panel. I know you use a lb on the outside but what do you use on the inside. I think a short say about 6-8" piece from the outside lb to another inside lb would be best looking.
Plumbvoltage is offline   Reply With Quote
Old 10-07-2009, 06:06 PM   #2
300zx's Avatar
Post
LB Looks the best to me.
300zx is offline   Reply With Quote
Old 10-07-2009, 06:33 PM   #3
Thumbs up
Defining Terms!
You can really Coin a Phrase or paraphrase the following; Every LB is an Elbow. But not every Elbow is an LB. There is also LR, LL and others. They all stand for something. I think Left-Right (LR); Left-Left (LL); (Or. the First "L" in each case could stand for "Load". Eliminate confusion Through Education! Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 10-07-2009, 07:04 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
L stands for L as in the general shape of the fitting.
the second letter denotes where the cover is:
LB cover on back
LR cover on right as you hold the fitting like a gun (long part would be barrel)
LL cover on left as you hold it like a gun.
you also have "N" fittings, "T" fittings and "X" fittings.
and technically they are called; condulets
and then there is the Arlington anybody:
http://fl2.shopmania.org/files/image...dy~7424878.jpg
Old 10-07-2009, 07:29 PM   #5
Post
LB cover on back
http://fl2.shopmania.org/files/images/7425/arlington-industries-930-1-1-2-anybody-universal-metal-conduit-body~7424878.jpg
You are 100% right. But sometimes a name sticks and (mistakenly) carried over to other, similar products. For example. "Channellock" is really a name of a manufacturer of adjustable pliers. alternatively, they were called "Water Pumps". But on the Condulets, the second letter stands for the shape and use. Lately, one major distributor (who shall remain nameless for logical reasons) is featuring a "Universal" Condulet, which can be converted to any shape, in order to speed up the work at construction sites!(No matter what) Don't Drink and Drive, Ever!!!
Old 10-07-2009, 07:54 PM   #6
nap
You talking to me?
nap's Avatar
check the link. That is the Arlington anybody I linked to.
and yes, condulet is actually a trademarked name owned by Crouse Hinds. My mistake. It would generically be referred to as a conduit body.
the second letter does not stand for the shape and use. The second letter signifies the location of the opening (cover side). . The first letter is the shape of the body. Just as when you look at a "T" (three conduit openings) and a "X" (actually more of a cross with 4 conduit openings). there is a couple that are not quite as self explanatory:
"C" fittings. They are simply connector with an opening and a cover and an "E" or "end" depending on who is calling it out which only has one conduit opening.
on a T body , the cover is generally on the side although I believe I recall one where the cover was on the back (TB?) In my perusing of the web, I saw a body I could only call a TLR. It was a T with openings on both sides.
Old 10-07-2009, 08:54 PM   #7
Thumbs up
Yes. But the LB, LR and LL are self explanatory. As far as Condulet being a Trademark (as opposed to a generic name) I remember, one of the first books I read about Electricity, in 1965, was Audel's Book on Practical Electricity. There, they called the Conduit Bodies, "Condulets"!
Old 10-07-2009, 09:16 PM   #8
nap
You talking to me?
nap's Avatar
wow, you learn something new everyday. The wordmark (a trademark consisting of a word) is in fact expired per the USPTO.
http://tarr.uspto.gov/servlet/tarr?r...entry=71015647
http://tess2.uspto.gov/bin/gate.exe?...003:30qp1l.2.1
It appears CH allowed it to expire (2006) for some reason although in 1965 is was still legally owned by CH. I suspect the use in the manner Audel used it may be an acceptable use such as the trademark fair use doctrine since it was not being used in a commercial use by it's inclusion.
If another manufacturer had called their bodies "condulets", then CH would have had an actionable grievance against them.
Old 10-08-2009, 05:47 AM   #9
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
If the wall is going to be finished, I sometimes add a female adapter to the LB, then use an angle connector and FMC up to the panel to avoid having an LB inside that has to be accessible.
Depending on how high it is outside, I'll just come in the back of the panel. I try not to use back to back LB's.
wirenut1110 is offline   Reply With Quote
Old 10-08-2009, 09:08 AM   #10
nap
You talking to me?
nap's Avatar
Female adapter and FMC?
Something sounds a bit incongruous.
Sounds like you might be mixing in some metal conduit with some non-metallic parts. Really need to be cautious about that and be sure the metal is bonded to the grounding system.
but yes, that is a(n) (essentially) reasonable installation. and yes, avoiding the LB's altogether is often preferable. Not knowing what the OP has going for an install, the panel opposite the meter is always a good placement, if possible.
Old 10-08-2009, 04:42 PM   #11
Rewards Points: 150
LB cover on back
Hey Nap! That is exactly the phrase my instructors said forty years ago in trade school (LATTC)..and I can honestly say there are a whole lot of journeyman electricians out there that mix condulets up all the time! (until I say your same little phrase)
__pete
HandyPete is offline   Reply With Quote
Old 10-08-2009, 05:48 PM   #12
It will be a detached garage with the pvc conduit coming out of the ground and going into the garage just above the foundation and then up about 3'-4' or so into the bottom of the panel on the inside. I plan to use a LB on the outside but what should I use on the inside?
Old 10-08-2009, 05:54 PM   #13
300zx's Avatar
Post
Sometimes a pvc 90 will work don't know how much space is there if that wont work use another Pvc LB
Old 10-08-2009, 06:36 PM   #14
Rewards Points: 510
That's why I suggested what I did. In your original question, there was no mention of this being service or a meter being involved.
When I run a circuit to a garage, I LB with a short nipple just inside the wall and convert to FMC with an angle connector. There's enough room inside the studs for the angle connector to make the turn and straight up to the panel. If the customer decides to put sheet rock up they can without cutting out for the another LB cover.
I'm not sure how changing from pvc to FMC is incongruous.(had to look that up)
Old 10-08-2009, 07:28 PM   #15
nap
You talking to me?
nap's Avatar
because FMC is metal and it must be bonded. I was simply reminding whomever installs in this manner to be sure the metal is bonded.
regardless though, I just happened to notice something you should check out wirenut:
nec 2005 378.42
re-routing central vac pipe-how to attach elbow piece yummy mummy Building & Construction 3 12-02-2008 11:58 AM
Connecting air cleaner to return air elbow jdelisle HVAC 1 07-10-2008 05:44 AM
Leak in elbow...how do I fix? gone_fishing Plumbing 8 01-30-2008 09:36 PM
Water main Elbow at House anagy007 Plumbing 4 12-17-2007 03:34 PM
LB or Elbow LAR234 Electrical 6 01-05-2007 07:30 AM
