Landscape Lighting Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2019, 04:12 PM   #1
Rewards Points: 46
landscape lighting wire
I am attempting to repair my old outdoor lighting and discovered that the wire in the ground has three (3) wires it looks like a 10 gauge outdoor wire. I purchased 12/2 outdoor wire; ran some lights with a new transform and everything worked. I discovered that the old wire that runs under my driveway is a 3 three wire. Why are there three wires? do I have to get different connectors with the three wire or shoud I just leave them and run new wire? The old transformer still works and puts out 12.5 volts.
Mike5163 is offline   Reply With Quote
Old 04-23-2019, 04:34 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 22,544
Re: landscape lighting wire
There may have been two separate circuits to distribute the load so there is less voltage drop at the end of the line.
The Following User Says Thank You to joed For This Useful Post:
Mike5163 (04-23-2019)
Old 04-25-2019, 02:39 PM   #3
Rewards Points: 306
It also provides an extra or backup wire should one of the two fail. I actually run outdoor plastic conduit in such situations so I can pull a new wire in the future rather than have to saw cut the concrete, etc.
Calson is offline   Reply With Quote
Old 04-25-2019, 04:33 PM   #4
Rewards Points: 46
sure is hard to pull this wire apart. I am trying to splice a section that is under concrete. Thanks for your response.
Old 04-25-2019, 04:56 PM   #5
Rewards Points: 2,340
Can you post a picture? Never seen any 3 wire low voltage landscape wire. Maybe someone used UF cable.
LawnGuyLandSparky is online now   Reply With Quote
Old 04-25-2019, 06:46 PM   #6
Rewards Points: 46
It is UF Cable. Wondering if I can splice the 12/2 wire to make it under the concrete. Can't pull the UF through so splicing is my only option if i use the UF wire.
Old 04-25-2019, 11:01 PM   #7
If you working on the 12 volt side of the system you can do whatever you want.
Old 04-26-2019, 06:56 AM   #8
Rewards Points: 46
Thanks for the reassurance and information. Its great to get advice and guidance from pros.
Thanks again!
WIFI thermostat? dommm HVAC 10 01-21-2019 04:28 PM
Light Switch Troubles mkallaway Electrical 10 01-14-2018 11:51 AM
Digitial Timer in 3 Gang box with (2) 3way switches and 1 single pole..confused. BCS Electrical 33 03-20-2016 11:30 PM
Landscape lighting?? Master Brian Landscaping & Lawn Care 4 10-14-2015 02:00 AM
Landscape Lighting? NightScapes Landscaping & Lawn Care 36 06-13-2011 06:37 AM
