Landscape Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 09-09-2014, 04:46 PM   #1
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Landscape Lighting
Old 09-09-2014, 04:48 PM   #2
E2 Electrician
Since so many questions come up about landscape lighting, thought I would post a few pics of how the splices should be done, and what a real low voltage transformer should look like.
The Following User Says Thank You to stickboy1375 For This Useful Post:
clw1963 (09-09-2014)
Old 09-09-2014, 05:45 PM   #3
Rewards Points: 1,832
Is there really any benefit to using a toroidal transformer?
Jump-start is offline   Reply With Quote
Old 09-09-2014, 05:52 PM   #4
E2 Electrician
Quoted from Q-tran, the maker of the transformer pictured...
Toroidal transformers are more efficient than the cheaper laminated E-I types for a similar power level. Other advantages compared to E-I types, include smaller size (about half), lower weight (about half), less mechanical hum (making them superior in audio amplifiers), lower exterior magnetic field (about one tenth), low off-load losses (making them more efficient in standby circuits), single-bolt mounting, and greater choice of shapes. The main disadvantages are higher cost and limited power capacity.
Old 09-09-2014, 05:55 PM   #5
I just toss a 12/24 secondary buck and boost up
The Following User Says Thank You to Jump-start For This Useful Post:
stickboy1375 (09-10-2014)
Old 09-09-2014, 05:57 PM   #6
E2 Electrician
I went to the Bahamas to do a landscape job, it was amazing... Q-tran's everywhere....
Jump-start (09-09-2014)
Old 09-09-2014, 07:56 PM   #7
Rewards Points: 1,306
I like those splices who makes them?
Also the conduit stub a lawn edge is a good idea. I wish my dog fence guys did that.
curiousB is offline   Reply With Quote
Old 09-09-2014, 08:36 PM   #8
dmxtothemax's Avatar
Rewards Points: 7,740
Not anything major !
A little less radiated flux,
A little more efficient.
Landscape lights don't care what tranny you use.
If there a cheap customer use a cheap tranny,
If the customer is a little more concerning use a torroid.
dmxtothemax is offline   Reply With Quote
Old 09-09-2014, 08:36 PM   #9
DITTO ?
Old 09-10-2014, 01:21 AM   #10
E2 Electrician
The spices are called ace connectors, one manufacture is King innovation, but you source them out online, they are not cheap, but the fail rate is very low, generally cause by installer error.
Old 09-10-2014, 01:27 AM   #11
E2 Electrician
As far as the transformers are concerned, we do much bigger installs, so we do a lot of In grade transformers, meaning they get buried in remote locations from any structures, let's see you bury any transformer than a q-tran and see how long they last.
Bahamas job....
Old 09-10-2014, 08:17 AM   #12
I thought you were kidding about Bahamas job. Nice road trip!!!
No concern of rain fall flooding out the transformers? My irrigation valve box gets flooded in big rainfalls as the ground get saturated and takes a while to perk away
Old 09-10-2014, 07:13 PM   #13
E2 Electrician
No, Q-tran specially designed all of its housings for DB rating. They also have to withstand heat since they are contained, they rock.
landscape lighting wire design; T-Method tarheelblue Electrical 6 12-04-2012 07:57 PM
Solar Landscape Lighting - Any generate REAL light? 99altrade Landscaping & Lawn Care 4 08-02-2011 12:15 PM
Landscape Lighting? NightScapes Landscaping & Lawn Care 36 06-13-2011 06:37 AM
DIY low-voltage landscape lighting?? kooshball Electrical 1 03-23-2010 05:36 PM
Help me pick out landscape lighting vanamc Landscaping & Lawn Care 3 05-04-2009 08:49 PM
