Knob And Tube - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2015, 01:33 PM   #1
Rewards Points: 2
Knob and tube
What causes no power to switches when breaker isn't tripped.. no gfci's are tripped but everything else on breaker is working... I have 2 3-ways switches that all of a sudden have no power to them... it's an old house with knob and tube wiring but panel is up to date with breakers
johnranieri29 is offline   Reply With Quote
Old 01-06-2015, 02:41 PM   #2
dmxtothemax's Avatar
Rewards Points: 7,818
Loose wires , faulty switchs , faulty cables.
Have you checked for power at the switchs ?
dmxtothemax is offline   Reply With Quote
Old 01-06-2015, 04:35 PM   #3
Rewards Points: 2
Brand new switches, they were working 5 minutes prior. They are 3 way switches, I didn't hook up the correct way the first time, working but not in the correct way. Turned off breaker to rewire the switches. Hooked them back up, turned on the breaker and no power. Everything else on the breaker is working.
Old 01-06-2015, 04:36 PM   #4
Rewards Points: 2
I checked the voltage, not just the switch
Old 01-07-2015, 05:21 AM   #5
General Contractor
Al_Amantea's Avatar
Rewards Points: 28
The switches are wired wrong.
There are 4 screws on each 3 way switch. 1 green, 2 brass, and 1 black or dark colored.
The green is the ground.
The 2 brass screws are the travelers to go between the 2 switches.
The darker ones or black attach to the line (hot) on one switch and the load (light) on the other switch.
A lot of times, the line and load are in the same box, and a 12/3 is run to the 2nd switch location. Just make sure that you wire it appropriately into the circuit and you will be ok. It helps to mark the white wire in the 12/3 with black or red tape on both ends to signify it is used for power in this case.
Al_Amantea is offline   Reply With Quote
Old 01-07-2015, 12:41 PM   #6
Oso954's Avatar
Rewards Points: 1,606
When did 12/3 become a Knob & Tube wiring method ?
OP, it would help if you post some pics of the wiring at each location.
Also, was the electric installed prior to 1923 ?
Oso954 is online now   Reply With Quote
Old 01-07-2015, 01:20 PM   #7
General Contractor
Al_Amantea's Avatar
Rewards Points: 28
True, but that info was given for the benefit of other readers also.
I do agree that pics of the wiring would be advantageous.
Old 01-07-2015, 04:24 PM   #8
Have you performed a voltage test on the switchs ?
What did you use ?
What where the results on ALL the terminals of both switchs ?
And yes a picture will help heaps !
Decommissioning Knob and Tube Perry401 Electrical 7 05-14-2014 10:04 PM
question about replacing knob and tube ocelli77 Electrical 2 11-24-2012 07:30 AM
Replace old Knob and Tube with Romex stevefrench Electrical 13 10-04-2012 06:59 AM
Knob & Tube -- Cellulose Insulation rlowe82 Electrical 23 11-08-2011 12:03 PM
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 12:17 PM
