Kitchen \ Bar Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2010, 01:23 PM   #1
Rewards Points: 214
Kitchen \ Bar question
Thanks everyone for helping me out during this. Hopefully this will be the last question for awhile. I am going to be pulling wires for the Kitchen \ Bar area this weekend and just wanted to get some advice here is what I am thinking.
- Stove on it's own 40 amp circuit
- over range microwave on a 20 amp circuit along with an outlet for the Bar TV
- Dishwasher on it's own 15\20amp circuit (no other outlets) haven't decided if I am going to do a disposal or not, if I do it would be on this circuit.
- 2 20 amp circuits with first receptacle being CGFI and 3 or 4 outlets after per circuit along counter top every 4 feet as needed.
- Fridge on its own 20 amp circuit with an outlet for future use.
Does this look all right or can I combine anything to save wire\space?
Also, for the range wire is 8-3 what I need or do I need 4 conductor cable? What is the distance maximum that 8 gauge wire can be ran? It will be a little over a 30' run.
Thanks so much for all of the help! The knowledge has been invaluable.
Abs777 is offline   Reply With Quote
Old 04-23-2010, 02:10 PM   #2
Sounds good, 8-3 is fine for 30'....even longer
Everything you are doing is what I would do
Its above code to have the fridge & MW circuits, but a great idea
We do not intend to have a disposal either, but I will run a 20a circuit just in case for DW
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Abs777 (04-23-2010)
Old 04-23-2010, 05:57 PM   #3
Master Electrician
Rewards Points: 5,084
8-3 with ground for the range.
brric is online now   Reply With Quote
kitchen design: should we remove inner wall(s)? ilyaz Kitchen & Bath Remodeling 4 10-26-2010 07:59 AM
removing load-bearing walls and moving the kitchen WannaReno Remodeling 2 04-02-2010 05:05 PM
Project floor plan for Kitchen and Bath Snav Kitchen & Bath Remodeling 0 01-25-2010 10:51 AM
Kitchen counter question axlmayhem General DIY Discussions 5 10-20-2008 09:32 AM
Kitchen walkway Design question dustandtools Building & Construction 1 10-14-2008 11:02 AM
