Kinda Stupid Question On New Wire Vs Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 10-20-2015, 10:41 AM   #1
Rewards Points: 560
Kinda stupid question on new wire vs junction box
Hey All,
This is pretty minor but bugging me for some reason. I am redoing my kitchen and am rewiring an old fan/light outlet with NM 14/3 so that I can install a switch (it was previously pull chain on/off). The fixture was BX running down a wall into the cellar and into a j-box to grab power from a 14/3 double breaker (the other hot is currently abandoned). I originally thought the BX was not accessible so had already run a 2-wire leg from the j-box to provide simple switching. I later learned I could get the BX out and in my excitement I did not think it through and simply replaced it with the 14/3, cutting it off at the j-box when I should have run it all the way back to the switch. Going over the top was not an option as there is a joist in the way of the top plate where the switch is.
Anyway, now I am faced with two choices. 1) run another leg of 14/3 from the j-box to the switch OR 2) pulling out the wire I just ran and replacing it with a longer run. This also allows me to scrap the j-box entirely if I run power all the way back to the breakers.
I know either way will work and be to code (I think). It's really a matter of just getting it done vs. doing it right. Thoughts?
giansean is offline   Reply With Quote
Old 10-20-2015, 12:11 PM   #2
Rewards Points: 3,416
Both ways are "right" and "correct". It is your free choice.
Don't forget that if you make connections in the j-box, the box cover must remain accessible.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
The Following User Says Thank You to AllanJ For This Useful Post:
giansean (10-20-2015)
Hot Tub Wiring Question - Wire Type? AidanD55 Electrical 10 03-18-2012 12:16 AM
Ground Wire Size Question Suprageezer Electrical 12 07-28-2011 03:00 PM
Stupid question about air in mortar. sukhenkoi Kitchen & Bath Remodeling 1 06-07-2011 11:06 PM
grounding old 2 wire junction to grounded junction gm8075 Electrical 3 03-28-2011 11:46 AM
Wiring a Spa and THHN question. skleinsmith Electrical 29 04-02-2010 11:41 AM
