Just To Confirm - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 10:40 PM   #1
Just to confirm
I have an old FP split phase fuse box outside just below my meter. Main fuse feeds a breaker box inside. My breaker box has the ground and neutral bonded together. That's wrong, correct? The outside fuse box counts as the first disconnect so the ground and neutral should be isolated in the breaker box. Right? Thanks
Mike in Arkansas is offline   Reply With Quote
Old 07-15-2010, 12:13 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you are correct in your assumptions.
The Following User Says Thank You to nap For This Useful Post:
Mike in Arkansas (07-15-2010)
Can Someone confirm my furnace diagnosis? beckkl HVAC 3 03-11-2009 09:16 PM
help, please confirm my plumbing work! boddah Plumbing 7 02-08-2009 03:55 PM
How to confirm 2nd stage burner working? mirob HVAC 49 12-29-2008 06:11 PM
Before I confirm with the HVAC guy... ciera HVAC 4 08-22-2008 06:58 AM
Just to confirm, no GFCI needed for hard wired pool pump..right?? Al the Diy guy Electrical 6 02-10-2008 12:28 PM
