Jungle Of Wires In 2-gang Box Too Tight - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By chandler48
Old 07-04-2017, 09:41 PM   #1
Rewards Points: 4
Jungle of Wires in 2-gang box too tight
The electrician installed 2 switches (1 triple switch and 1 single pole single switch) in a two gang box and with all the wires it is too crowded to press the switches in and put the cover plate on.
The electrical installation was done before the drywall was installed so at the time it seemed okay to leave the switches dangling. I didn't realize they wouldn't fit.
Now I need to consider alternatives. One alternative is to remove the 2-gang box and replace it with a 3-gang box to give excess wiring some elbow room. Or, reduce the bulk of the wires by consolidating the wires but I can't see how.
Opinions, tips, tricks, solutions, links are welcome.
Jungle of Wires in 2-gang box too tight-img_5582.jpg   Jungle of Wires in 2-gang box too tight-img_5589.jpg   Jungle of Wires in 2-gang box too tight-img_5586.jpg
lorikoliver is offline   Reply With Quote
Old 07-04-2017, 10:06 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 694
Re: Jungle of Wires in 2-gang box too tight
Unless the box is smaller than 30 cu in which I doubt, it is large enough. You need to learn how to fold the wires. The grounds need to be consolidated and leave 2 pigtails.
Sent from my RCT6203W46 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
lorikoliver (07-06-2017)
Old 07-05-2017, 05:55 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 4,668
If this is protected by a 15 amp breaker you are ok. Your "electrician" mixed 12 gauge and 14 gauge in the box. I don't understand why he didn't twist all the ground wires and leave two pigtails, either.
jbfan and Jim Port like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Old 07-06-2017, 02:35 AM   #4
Disrespectful to dirt
Fishbulb28's Avatar
Rewards Points: 2,002
My Carlon catalog shows that box has a volume of 32 cubic inches. You're currently at 33.75 in3 of box fill. Either your electrician didn't understand how to do box fill calculations or is very bad at math.
Switching to a three gang box is certainly one way to solve the problem. But if you wish to remain with a two gang box there are other options available. Do you have access to the wall behind the box? How much drywall patching are you willing to do?
Fishbulb28 is offline   Reply With Quote
The Following User Says Thank You to Fishbulb28 For This Useful Post:
Old 07-06-2017, 02:38 AM   #5
Fishbulb28's Avatar
Look again. The two white cables are actually wider than the newer yellow ones. None of the insulated conductors are smaller than the ones known to be 12 gauge. There are no 14 gauge bare equipment grounding conductors present.
The two white NM cables are 12 gauge, just not new enough to be color coded.
Old 07-06-2017, 05:08 AM   #6
Naildriver
chandler48's Avatar
It does appear to be so. Wonder how he came across the older sheathed 12 nm ?? Unless they were original to the box. Good catch.
Larry......
Old 07-06-2017, 09:29 AM   #7
Rewards Points: 4
Thank you, everyone. The problem has been resolved. The electrician returned and made everything fit, all tight, safe and secure.
Old 07-06-2017, 09:32 AM   #8
Like shoving 5#s of sht in a 3# bag!
Lol
Sent from my LG-K550 using Tapatalk
trentonmakes is offline   Reply With Quote
Tags
ground , overload , wires
Cramped Outlet (Gang) Box Oyiwaa Electrical 17 03-23-2017 08:10 PM
Digitial Timer in 3 Gang box with (2) 3way switches and 1 single pole..confused. BCS Electrical 33 03-20-2016 11:30 PM
Can you use wire nuts on a fan light switch with silvery looking wires? amodoko Electrical 4 10-28-2012 08:26 PM
Cutting/capping old cables - What to do with grounds & put these in oversize gang box darlingm Electrical 3 12-22-2011 11:40 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
