Junction Box Under Sink - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-18-2010, 02:38 PM   #16
Electrician
Proby's Avatar
debiasio, the fridge doesn't need it's own circuit. You need 2 SABC. If you don't have space, it's time for a sub-panel or an upgraded main panel.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-18-2010, 02:40 PM   #17
Rewards Points: 156
Our local code specified that fridge must be on its own circuit.
moondawg is offline   Reply With Quote
Old 08-18-2010, 02:42 PM   #18
Electrician
Proby's Avatar
Another design issue rolled into the code under the guise of a safety issue- the sole purpose of the code.
Old 08-18-2010, 03:11 PM   #19
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Big N8 is offline   Reply With Quote
Old 08-18-2010, 03:52 PM   #20
Originally Posted by debiasio View Post
What is the reasoning behind this code? Why would anyone need up to 40A (2 x 20A circuits) to serve the kitchen, especially if the fridge, range, dishwasher and microwave are on other circuits?
My toaster & microwave will kick the breaker off on a 20a breaker
I also have a toaster oven, so I have (3) 20a SABC
Nevermind the coffe maker, (2) crock pots, mixer or (2) blenders
Fridge is on its own circuit
Old 08-18-2010, 03:55 PM   #21
Just call me Andrew
Rewards Points: 1,032
I have heard people mention here that the disposal and dishwasher can be on the same circuit. Is that incorrect?
Andrew
secutanudu is offline   Reply With Quote
Old 08-18-2010, 05:29 PM   #22
My 26 cu ft fridge is rated at 11.6a, its on a dedicated 15a circuit
I haven't tested to see how much it pulls on startup VS while running
My 18cu ft fridge pulled 8.3a at startup, it is rated at 7.3a
Once running it drops down to 330w...then down to 130w
Any other device I normally use would kick a 20a circuit breaker off if the fridge pulls 11.6a
My understanding DW & disposal can be on the same circuit
Old 08-18-2010, 07:58 PM   #23
Rewards Points: 91
junction box under sink
i guess i didnt think of the various gadgets used in a kitchen. ill just add the 2nd SABC circuit.
my fridge only pulls 4.5A, according to the label. guess it doesn't need to be on its own circuit, but its fine the way it is.
debiasio is offline   Reply With Quote
Old 08-18-2010, 11:14 PM   #24
Electrician
Proby's Avatar
I've always put the fridge on it's own circuit, it's just a logical thing to do. However, if you have some reason why you have to limit circuits, you would need a second SABC before a dedicate fridge receptacle.
Old 08-19-2010, 08:07 AM   #25
Super Moderator
joed's Avatar
Rewards Points: 23,958
In Canada the fridge MUST be on a dedicated circuit. But believe it not a freezer is not required to be dedicated circuit.
Advice on Replacing Rusted Bath Undermount Style Sink mdonovan Plumbing 12 11-09-2013 02:36 PM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 06:24 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
