Is A Junction Box Required? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-08-2009, 12:53 PM   #16
Okay Mr Wire Nut Pants what's the secret?
Experience.
I have installed tens of thousands of splices and have repaired hundreds of homeowner/handyman splices.....maybe thousands.
I rarely use sidecutters to twist wires so most of your method doesn't apply.
You left out the number one instruction.
1. Cut wires the same length! This helps keep the ends from pushing out of the nut. One short/long wire makes the task difficult.
2. Strip the wire using the proper tool properly and there is no chance of nicking it.
3. Hold the wires tightly with a kung fu grip, ends evenly together, and work the nut on. Continue twisting until the wires start twisting around themselves.
When you can snatch the wirenut from my hand Grasshoppa, it is time for you to go
220/221 is offline   Reply With Quote
Old 07-11-2009, 12:33 AM   #17
MT Stringer's Avatar
Rewards Points: 254
Job Complete!
Well, almost. Still have to install the crown molding around the top of the box.
Upon further inspection, I discovered I had just enough romex to reach to the new elect box location without having to deal with a junction box in the attic.
I built a fur down box out of Birch plywood and painted it the same as the walls. I got a pretty good fit and in real life, it looks pretty good.
Thanks to all who offered their advice.
Here's a few pics.
Mike
I got a pretty good fit.
Finished! Dang a bulb burned out right after it was installed! :-(
A nook where the old medicine cabinet used to be.
MT Stringer is offline   Reply With Quote
Old 07-11-2009, 10:31 AM   #18
Nice job, are the 2 outer lights on seperate switches?
Old 07-11-2009, 11:13 AM   #19
Rewards Points: 254
Dave, they are all on the same switch. Do you think I should separate them? We are using the energy saving bulbs rated at 13w - replacement for 60 watt bulbs.
Mike
Old 07-11-2009, 11:20 AM   #20
I use the CFLs too
I have the overhead light on 1 switch
Then the 3 vanity lights (3 bulbs) on another switch
I was just asking because the one on the left was off
Old 07-11-2009, 11:32 AM   #21
Rewards Points: 254
That bulb was one of four in a pack and it went out within 5 minutes of installing it! :-(
Mike
Old 07-11-2009, 12:17 PM   #22
Ah - hope you brought it back to be replaced
I put in a built in shelf off to the side too in my bathroom
Old 07-11-2009, 01:59 PM   #23
Rewards Points: 254
Yessir, we just got back. No problem making the exchange.
Mike
Mounting junction boxes in attic, are both of these locations acceptable? diymonkey Electrical 33 04-09-2009 07:24 AM
2 Light Fixtures, one junction box NickSna Electrical 4 04-05-2009 03:02 PM
Light Fixture installed-no junction box? AdamsHouseCat Electrical 7 02-02-2009 11:03 AM
Junction box in patio ceiling I_think_I_conduit Electrical 6 08-20-2008 07:28 AM
Junction Question? fw2007 Electrical 10 03-31-2008 11:03 AM
