Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 11:17 AM   #1
Rewards Points: 93
Junction Box
Making a few connections in a junction box in an attic. Want to verify I do it correctly. there are four 12/2 Nm yellow wires going in. I crimped all the grounds together. Do I also have to ground the actually box?
bfan781 is offline   Reply With Quote
The Following User Says Thank You to bfan781 For This Useful Post:
dicklawless (11-20-2010)
Old 11-20-2010, 11:38 AM   #2
Rewards Points: 150
If it's a metal box, yes.
emolatur is offline   Reply With Quote
Old 11-25-2010, 12:08 PM   #3
Rewards Points: 93
yeah, the box is metal and i assumed that it did need to be grounded. Is there a specific way that they are going to want to see it done? I tried screwing in a green ground screw, but it wasn't the correct size and didnt bite. Do they make a specific ground screw or is there another way to do it.
Old 11-25-2010, 12:11 PM   #4
Rewards Points: 54
Try these -
http://www.electriciantalk.com/f2/gr...allation-8024/
tribe_fan is offline   Reply With Quote
Old 11-25-2010, 12:48 PM   #5
Rewards Points: 330
ground screws are 10-32.one of the holes should have threads.some boxes don't.
oleguy74 is offline   Reply With Quote
Old 11-26-2010, 07:50 AM   #6
Lowes sells the green ground screws. They are a different size then the ones on the outlets and switches. They come in a pack of 10 or 100 and despite the fact that I needed 15 the price differential made it more reasonable to buy 100 rather than buy 2 packs of 10. They fit all of the metal boxes (outlet, switch, j-box, etc.)
jerseyguy1996 is offline   Reply With Quote
Split 220v in a junction box into 2x 110v dsoelter Electrical 10 07-10-2010 09:25 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
Light Fixture installed-no junction box? AdamsHouseCat Electrical 7 02-02-2009 11:03 AM
Junction Question? fw2007 Electrical 10 03-31-2008 11:03 AM
