Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2010, 01:04 PM   #1
Rewards Points: 193
Junction Box
I'm redoing/adding lights and switches in my kitchen and hallway. The 15 amp feed that I will be using for the lights is up in the attic (easy access.) Is there a problem with bring the feed into a junction box in the attic then branching off to the four individual switch boxes from there rather then pig tailing in the switch boxes? Thanks
Jack E is offline   Reply With Quote
Old 04-27-2010, 01:21 PM   #2
Licensed electrician
Rewards Points: 3,662
As long as the rules for accessibility and box capacity are met you should be fine.
Old 04-27-2010, 02:48 PM   #3
Rewards Points: 193
Thanks for the confirmation.
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
Light Fixture installed-no junction box? AdamsHouseCat Electrical 7 02-02-2009 11:03 AM
Junction Question? fw2007 Electrical 10 03-31-2008 11:03 AM
Old House - no junction box - HELP! Designman20 Electrical 22 10-11-2007 04:58 PM
