Jacuzzi Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2009, 04:12 PM   #1
jacuzzi switch
The switch on my tub will only work when it is pushed in. If let off the switch it turns off. Is this a switch problem or is the pump wired in wrong? Shouldn't the pump turn on when the switch is pushed down and turn off when pushed back down?
barmaid is offline   Reply With Quote
Old 11-16-2009, 04:30 PM   #2
Is this the air actuated switch on top of the tub deck?
jerryh3 is offline   Reply With Quote
Old 11-16-2009, 04:31 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it sounds like the switch is bad. Does it "click" when you push it in? Did it used to?
edit: good point by jerry. I forgot about the air operated switches
Old 11-16-2009, 04:50 PM   #4
The switch is a vacuum switch I think. It has a clear tube running from the switch to the pump. When you push the switch in, and yes it is on top the tub. The motor clicks on. As soon as you let off the switch it turns of. I did replace the switch on the tub but not the switch in the pump.
Old 11-16-2009, 04:54 PM   #5
nap
You talking to me?
nap's Avatar
the switch at the pump is most likely the problem. There is a mechanical detent in the switch that apparently is not working. The air activator simply works as an extension of your finger.
Old 11-16-2009, 04:55 PM   #6
Thank you.
Old 11-16-2009, 04:56 PM   #7
The air switch is probably bad.
Possibly the tubing is loose or has a small leak which doesn't allow enough pressure to fully activate the switch.
220/221 is offline   Reply With Quote
Old 11-12-2010, 03:31 PM   #8
Sorry to bump such an old thread, but I have a similar issue. I spent an hour or so today getting the control panel to work, which it ended up doing. Then my wife came home and it looks like she jammed the button too hard/deep (this is an air actuated power button) and now the tub is stuck on and can't be switched off.
I took the panel apart again and after unplugging the tub, I can clearly hear the switch clicking on and off, but no matter what the tub remains on. Is it possible that the switch is clicking, but not hard enough? Or could the switch have blown at the pump? Any help would be appreciated. Thanks.
Chird is offline   Reply With Quote
Old 11-12-2010, 03:49 PM   #9
nap
You talking to me?
nap's Avatar
the switch may have been damaged so the contacts are jambed together somehow or were welded together somehow. If it is clicking, I would think that would be the most likely problem
single pole switch for jacuzzi tub kodeblue Electrical 6 09-19-2009 11:48 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
