Insulation / Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 03:08 PM   #1
Question
Insulation / wiring
I would like to insulate and poly my basement. Would this be considered a finished room according to the Ontario Elecrical Code and have to be wired accordingly?
John
JLambert is offline   Reply With Quote
Old 03-19-2010, 09:40 PM   #2
Just call me Andrew
Rewards Points: 1,032
bump for john. Not familiar with canadian code at all...
Andrew
secutanudu is offline   Reply With Quote
Old 03-20-2010, 04:38 AM   #3
Remodeling Contractor
Codes follow the NEC for the most part. Basically allow 3 watts of power for every 3000 square feet. An outlet must be placed on any 2' and over wall and one must be within 6' along any point on any wall. (12' feet apart). Usually you will have one circuit for the outlets and another for the lights.. I would use 12/2 for the outlets and 14/2 for lights. If you are using an entertainment system add a circuit to this location.
Old 03-20-2010, 06:19 AM   #4
An old Tradesmen
Rewards Points: 2,904
Contact your local code department.
Canadian code may differ or have additional requirements from USA code.
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 09:11 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
Basement - Wiring & Insulation heybrady Electrical 8 03-10-2008 09:37 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
