Insulating Around Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2010, 03:55 PM   #1
Hey everyone-
I have an older house- I'm remodeling the foyer. I know you cannot put fiberglass insulation around knob and tube wiring. Here's a picture of the type of wiring I have- doesn't appear to be K&T but not modern either. Can anyone say what type is it and is it safe to insulate around?
Pic:
http://i746.photobucket.com/albums/x...b/DSC00112.jpg
Thanks!
-Greg
c00rdb is offline   Reply With Quote
Old 07-18-2010, 04:00 PM   #2
Electrician
Proby's Avatar
While the walls are open, why not upgrade to some newer romex?
Proby is offline   Reply With Quote
Old 07-18-2010, 04:19 PM   #3
If you don't upgrade, you will be using heat shrink tubing to piecemeal replace your crumbling and brittle insulation on the wires.
For the thermal part, these equations
http://www.electrician2.com/ampacity.htm
can, in principle, be waded through.
Old 07-18-2010, 08:34 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Yes, without having to wade through equations and formulas, you CAN insulate around that cable.....if you really want to.
Personally I would also replace ANY of that stuff if the walls were open.
Old 07-18-2010, 09:34 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by c00rdb View Post
doesn't appear to be K&T but not modern either. Can anyone say what type is it and is it safe to insulate around?g
that's just older style NM (Romex). Totally safe to insulate around it.
Old 07-18-2010, 10:54 PM   #6
" Euro " electrician
frenchelectrican's Avatar
That is older style of NM cable but as long the wall is open I think I really suggest ya to run new cables as need to to bring it up the code due the older style NM most case they do not have grounding conductor at all.
And with walls open you can able install new recepales and swtiches and luminaire junction box as well { if you going to install the ceiling fan it will be wise to install the proper juction box that rated with ceiling fan useage }
Merci.
Marc
Old 07-19-2010, 07:18 AM   #7
If it were me I would definitely replace that old stuff. It looks like it wasn't installed right in the first place. Notice how the wire on the right is dangling out of the hole? There does not appear to be a proper clamp in the box. Abrasion of wire to metal could cause the box to become hot and electrocute someone since the old wire has no ground.
SleepyDog is offline   Reply With Quote
Old 07-19-2010, 09:07 AM   #8
Electrician
Proby's Avatar
FWIW, some of that old Romex does have a small EGC in it. In my home they would pull the small wire back out of the box and attach it to a screw on the outside of the box, for some strange reason.
Old 07-19-2010, 09:32 AM   #9
47_47's Avatar
Rewards Points: 320
They did this at my home also. The only reason that I can come up with is the metal boxes that they used are very shallow. Also the ground wire is smaller than the rest of the wires on the older NM. I'll pile on and say replace it.
47_47 is offline   Reply With Quote
Old 07-19-2010, 10:35 AM   #10
Electrician
Proby's Avatar
Nice, at least I'm not the only one!
One thing they did that makes it worse is that they put the ground wires under a screw towards the front of the box, so that screw protrudes into the box. That's fine with normal devices, but when you go to put a GFCI, Dimmer, Timer, etc. in they won't fit because the screw is there. So now I have to try and sawzall the end of the screw off without shaking the box too much and cracking the plaster
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
