DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   insulate & vapor barrier around electrical box (https://www.diychatroom.com/f18/insulate-vapor-barrier-around-electrical-box-69862/)
acerunner 04-26-2010 01:57 AM
exterior walls require insulation & vapor barrier. Electrical boxes on exterior wall breaks the vapor barrier if the box itself is not sealed. How do I maintain a sealed vapor barrier around the box? I've seen vapor barrier wrapped behind the box, but I dont understand where the cables would come in from. The cables will have to also poke a whole through the vapor barrier, so how do you seal that around the cables?
teamo 04-26-2010 09:44 AM
I believe they make a plastic box that is nailed to the studs and then the electrical box is installed inside of this. It gets sealed with foam or silicone for the penetrations and the vapor barrier is sealed to the face of the box with silicone.
secutanudu 04-26-2010 10:14 AM
I had this same question actually. I've seen some stuff that Mike Holmes uses, it's like a rubbery material that is wrapped on the back of the box. Any idea what this is or where to get it? Maybe a supply house would have it.
What about using the foam weather stripping behind the outlet? That would block a fair amount of moisture, right?
http://dinogy.com/images/blog/outlet-sealers.jpg
baum 04-26-2010 02:28 PM
Check your big box stores. I found at one near me a molded plastic (6-8mil) that has flanges incorporated into it. Then you just tape your VB to it.
see pic:
http://images.google.com/imgres?imgu...HcO78gatw6WrDw
acerunner 04-26-2010 03:22 PM
thanks. I found one such box here: http://www.lessco-airtight.com/
But with that, you would still need to find a way to seal the hole where the wire come through this box. In the picture, looks like they taped it or something. I think a putty or silicone (as you mentioned) would work well here.
secutanudu 04-26-2010 03:24 PM
They don't sell these at my local big-box store or electrical supply house. I don't have time to order one - think plastic wrap on the backside of the box with the foam underneath the cover plate will suffice?
acerunner 04-26-2010 03:24 PM
Yeah, I saw that episode. It was like a sheet of putty that he wrapped around it. Sealed right around the wire and everything. That episode was about sound deadening insulation, so I assumed the wrap was for sound deadening, but the same concepts apply to thermal insulation as well.
Gary in WA 04-26-2010 10:32 PM
http://www.buildingscience.com/docum...ecommendations
http://www.ecohomemagazine.com/energ...gy-claims.aspx
Be safe, Gary
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
