Insulate Conduit For Main? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2009, 07:48 PM   #1
Insulate conduit for main?
Need to upgrade service but want a simple fix for now. Pigtail comes in through roof, through panel, out to meter and back to panel. Just about every large conduit in the panel gets condensation dripping once it gets real cold out. Can I spray foam in the conduit to seperate the warm inside air from the cold outside air to stop the dripping?
Old 12-22-2009, 07:52 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,970
No not foam. You need what is called duct seal. It is made specifically for electrical conduits.
Old 12-22-2009, 08:10 PM   #3
Is that a spray ? I'm not going to push anything in with all that unfused wire running in and out.
Old 12-22-2009, 08:18 PM   #4
Rewards Points: 6,652
Call an Electrician that has the proper gear. This is something that should have been done at install, not something that you the home owner should do without the proper training or protection gear.
Old 12-22-2009, 08:29 PM   #5
Will do! Didn't know if it was a DIY job or not but sparky will get paid before I get killed.
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 05:25 PM
Sealing conduit coming into house encased with waterline pacamaroman Plumbing 3 06-18-2009 08:48 AM
Running conduit for a pool light KyMike Electrical 12 06-17-2009 03:02 PM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 05:25 AM
