Installing Remote Controlled Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2009, 09:04 PM   #1
installing remote controlled fan
I am installing an outdoor Savoy House ceiling fan equiped with remote control. I do not want to use the remote. May I install the fan without the reciever and use a fan control switch? The installation manual states that this fan may not be installed with a fan control switch or a solid-state fan switch. Is this due to the type of fan motor or because they do not want it installed at the same time the receiver is installed.
bart77 is offline   Reply With Quote
Old 09-01-2009, 01:07 PM   #2
J. V.'s Avatar
Rewards Points: 370
First, I always try to follow the manufacturers instructions. Try the fan rated speed control and see. You may have to go with a simple snap switch if that will not work. Whats the model number?
I'm just curious. Why buy a fan with remote and not use it?
Old 09-01-2009, 07:10 PM   #3
If your fan has a black, white, blue and green wires, you can use whatever switch you want.
If it only has black,white and green, you are stuck with the remote.
You can eliminate the remote on most fans but not all of them.
220/221 is offline   Reply With Quote
Old 09-01-2009, 08:37 PM   #4
The model number is 52-525-50-40 monticello edition. The fan does have blue for lights, black for fan, white neutral and ground.
Old 09-01-2009, 09:05 PM   #5
Thanks, I have blue wire and will try the installation without the remote and use the fan control switch
Remote with whole house fan? jman1 Electrical 11 05-23-2010 09:07 AM
Missing Wireless Remote - Motorized Plasma TV Lift JanFan Home Theater 3 03-19-2009 08:46 AM
Installing fan with 1/2 hot or remote? zombie911 Electrical 8 08-23-2008 02:30 PM
Installing Aspire Remote Smart Dimmer sk72 Electrical 8 03-19-2008 09:16 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
