Installing Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2010, 08:44 PM   #1
installing recessed lighting
I've never installed recessed lighting before, the housing is just touching the sub floor above. it is a I/C rated housing is this OK?
tucci is offline   Reply With Quote
Old 06-09-2010, 09:53 PM   #2
Knows everything but that
Rewards Points: 150
I dunno but good question. Id imagine since they are IC that it wouldnt be an issue. However, thats just a common sense assumption and often times you know what it happens when you assume.
JakAHearts is offline   Reply With Quote
Old 06-09-2010, 11:16 PM   #3
It should be fine, but they do make a can for 2" x 6" height joist HALO or ELCO makes one, I think I would go for one of these just to be on the safe side. I assume your floor joist are smaller than 2" x 10" or 2" x 8"?
delta_kilo is offline   Reply With Quote
Old 06-10-2010, 06:14 AM   #4
The joist are 2 x8 but the house is 40 years old and they have basically shrunk to about 7 1/4. The can is 7 high so it's just a little close. There is no insulation. And the can is rated for insulation contact.
Old 06-10-2010, 06:39 AM   #5
Just call me Andrew
Rewards Points: 1,032
I just bought a 6" Juno (I think) can from my local electrical supplier that is I.C. rated, and meant for 2x6 joists (5 3/4" tall). They have it in both remodel and new construction:
http://www.junolightinggroup.com/pro...ntent_extra_13
Andrew
secutanudu is offline   Reply With Quote
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed lighting in billiard room? kcrossley2 Electrical 11 01-11-2009 08:00 AM
Recessed Lighting vs Electrical/Mechanical/Fire Code 909 Electrical 3 05-21-2008 01:11 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
