Installing An Outside Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2011, 04:23 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 578
Installing an outside outlet
I want to install two outside outlets on my garage. One very high up for the Christmas lights and one for plugging in the car in the winter. It's brick. Do I just cut a hole into the brick, put in some hydrolic cement, insert an outside rated box, and run regular romex to the box? Or do I need outside rated wire for that? Is the hydrolic cement sufficient for waterproofing, or should I do anything else?
Old 09-11-2011, 04:51 PM   #2
Not sure of you're installation situations. What we normally do is run the conductors outside of the house in water tight conduit to weather proof surface mount boxes. With a thhn/thwn type wire (No outer jacket on the wire like romex or armored cable) feeding it. And of coarse a gfci receptacle or circut breaker.
AlKapone is offline   Reply With Quote
Old 09-12-2011, 08:33 AM   #3
Wire Chewer
Rewards Points: 578
Can I still use romex? Will be easier than buying 3 rolls of wire (one black one white, one bare) Then again guess it would not hurt to have.
Old 09-12-2011, 10:40 AM   #4
Rewards Points: 256
Some stores sell THHN wire by the foot.
michaelcherr is offline   Reply With Quote
Old 09-12-2011, 10:52 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
Squirrel,
Not sure about Canada, but down here as long as the romex goes through the wall directly into the box it is compliant.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following 2 Users Say Thank You to rjniles For This Useful Post:
AlKapone (09-13-2011), Code05 (09-12-2011)
Old 09-13-2011, 07:21 PM   #6
Wire Chewer
Rewards Points: 578
Good to know, that's pretty much what I figured too.
installing an outlet for an above ground pool. pbhound Electrical 2 05-22-2010 11:03 PM
NEC for installing an outlet in a crawl-space? kooshball Electrical 7 03-28-2010 08:15 PM
Installing 120VAC Outlet DK75 Electrical 4 11-26-2007 03:51 PM
Help on installing a 220v outlet BobRankin Electrical 24 10-23-2007 05:32 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
