Installing Outlet On Existing Drywalled Wall - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 08:14 PM   #16
Master Electrician
plastic boxes aren't code in canada yet. Home depot does carry them but as the previous poster said they cost a mint. We use plastic and metal boxes more in the commercial/construction sector but given the choice between the two i still prefer good old solid metal
andrew79 is offline   Reply With Quote
Old 06-04-2010, 09:26 PM   #17
Rewards Points: 506
If you are woried about the vapor barier, get a can of expanding foam (or has it been outlawed in Canada? I was hearing something about offgassing a while back)
forresth is offline   Reply With Quote
Old 06-04-2010, 10:12 PM   #18
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
I don't recall anything about it being outlawed. What I usually do is just tape up whatever I damage with red tape. I could also add foam around where the box will go.
Or, just fill the whole box with foam! I'm sure an inspector would love that one.
Old 06-04-2010, 10:37 PM   #19
Rewards Points: 506
I actually did that once.
some oldschool wiring were the insulation was crumbling when it got moved.
I figured that it would be the perfect way to keep it from moving
I was woried about the vibrations from a nearby ceiling fan.
I would have just rerun the wire, but I couldn't get to it all without a major remodel of the house.
Old 06-05-2010, 12:08 AM   #20
There are plastic vapour barriers for boxes. You could run the wires into it and put the box into it also.
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
Home Depot / Canadian Tire both have them.
You can then red tape them to your existing vapour barrier.
tdeg807 is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
How to place a new wall in a continuous mathematical alignment with existing wall Frye Building & Construction 9 03-31-2010 09:11 PM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 09:03 AM
Installing outlet...please help H2O Engr Electrical 4 02-15-2010 11:06 AM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 10:30 PM
