Installing An Outlet For An Above Ground Pool. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2010, 09:32 PM   #1
Question
installing an outlet for an above ground pool.
first off i would like to thank you all for your help.
im getting a little confused with section 680, especially sections 680.21 (5) "cord-and-plug connections. pool associated motors shall be permitted to employ cord-and-plug connections. the flexible cord shall not exceed 900mm (3 ft) in length. the flexible cord shall include an equipment grounding conductor sized in accordance with 250.122 and shall terminate in a grounding-type attachment plug."
and
section 680.22 (1)(2) "(circulation and sanitation systems, and equipment) employ a locking configuration."
does this mean that i need to cut off the end of the cord that was supplied with the motor and place a new plug that will twist and lock into a locking receptacle?
im installing a single circuit 120 v 20 amp line; the receptacle is rated at 20A GFCI, it will be in a weather proof housing. i called the city inspector and he said that i needed to have the locking receptacle.
can someone please clear the muddy waters for me.
thanks again.
pbhound is offline   Reply With Quote
Old 05-21-2010, 09:42 PM   #2
Licensed electrician
Rewards Points: 3,654
I agree with the locking plug request. However, cutting the cord cap off the pump will void the listing. I don't know why the pumps can't come with a twist lock card cap.
Old 05-22-2010, 11:03 PM   #3
would a locking receptacle box be ok?
oh and i went to lowes to day to find a locking plug and receptacle and all i could find were ones for a generator. is this the item that im supposed to use?
help with installing light with no ground jayp Electrical 2 02-05-2010 10:07 AM
Grounding an above ground pool wcolon Electrical 18 09-02-2009 02:25 PM
installing an electrical outlet with 3 sets of wires + ground dsparks Electrical 7 07-08-2009 06:18 PM
Replacing cord on a 1.5 hp above ground pool pump LeeAmes Electrical 23 04-20-2009 01:45 PM
Outlet without Ground water_cutter101 Electrical 10 12-30-2007 08:25 PM
