Installing Outdoor Recepticle? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 06:08 PM   #1
Rewards Points: 83
Installing outdoor recepticle?
I need to install an outdoor recepticle. I have a outdoor box, gfci, and in use cover. Can I mount the box on the wall and just run Romex into the back hole on the box?
Ebierley is offline   Reply With Quote
Old 05-17-2013, 06:16 PM   #2
Rewards Points: 18,468
Ok what type siding do you have?
What type box do you have?
Old 05-17-2013, 06:16 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Yep, with a connector.
The Following User Says Thank You to stickboy1375 For This Useful Post:
MTN REMODEL LLC (05-17-2013)
Old 05-17-2013, 09:17 PM   #4
Rewards Points: 83
Cedar shingles. The box is a wet location outlet box from HD. RIH31LM
Old 05-17-2013, 09:25 PM   #5
Rewards Points: 6,652
I used NM on both outside outlet boxes on the side of my house. The one thing that we did, before screwing down the boxes, was place a nice sized bead of silicone where it would be against the aluminum siding, so that it would seal out any moisture or drafts from getting into the hole that goes through the sill to our basement. Then on the basement side, foamed around the hole to also further seal to keep out ants, etc..
Old 05-17-2013, 10:02 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
In my area, some inspectors would let it go, some would not. Some inspectors consider the inside of a WP box the same as the inside of exterior conduit...and I tend to agree with them.
Old 05-17-2013, 10:02 PM   #7
ericmunyon12345's Avatar
You really should use a rigid pipe nipple that enters the house and screw on a plastic bushing.
ericmunyon12345 is offline   Reply With Quote
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 09:54 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 06:19 AM
Installing laminate around doors??!! RonR Flooring 8 01-05-2008 07:38 AM
Installing T&G birch ceiling NeedHelp Building & Construction 6 12-29-2007 08:09 AM
